996 GT2/GT3 Forum 1999-2005
"Clocking" r6's on rims
Old 09-25-2009, 11:58 AM
1fastline
1fastline's Avatar
Default "Clocking" r6's on rims
After 7 track days I finally wore out my r6's. (245/315) Great tires but I could not keep them from spinning on the stock rims. Anybody else have this problem? I ended up having to remount the tires way to often. I mounted my original Pirelli Corsas(235/295) and did not have the problem. I tried roughing up the rims, various sticky stuff etc. with no results. Any thoughts?
Old 09-25-2009, 12:34 PM
996FLT6
996FLT6's Avatar
I don't think u can do nething bout it- just monitor tire pressures. Mooty will chime in : ). Maybe your driving too fast : ). Mike
Old 09-25-2009, 01:01 PM
himself
himself's Avatar
I had the same problem with R6s, so I started marking the valve stems and noticed that the tires would sometimes spin 10-20 degrees per session. After about 45 degrees, the tire needing a rebalance.
They continued to spin on the rim until we started putting hairspray on them. Aqua Net worked well and stopped the spinning. Yup, $0.99 Aqua net... You could probably use Herbal Essence though - as your tires will smell better.
-td
Old 09-25-2009, 02:28 PM
ritzblitz
ritzblitz's Avatar
Someones been doing the herbal...
Old 09-25-2009, 06:22 PM
LVDell
LVDell's Avatar
Aqua net is the ticket. And as crazy as it sounds it MUST be aqua net unscented extra super hold (purple can) for best results. I have tried other with no such level of performance. Used on R6's and Slicks and my tire rotation stopped! My guy at Discount Tire looked at me funny the first time when I told him to DRY MOUNT the tires and spray the beads with aqua net only for lube to mount. Now he asks for the can before I even head up to the shop
The problem you had was you crossed over the threshold of braking g's that the rim can handle what the tires can. The R6 and slicks are the crack that we love but the price to keep the wheels balanced is a can of $.99 aqua net
Old 09-25-2009, 06:25 PM
va122
va122's Avatar
Seriously?? Mine spin all the time too
Old 09-25-2009, 06:28 PM
LVDell
LVDell's Avatar
Crazy as it sounds, that's the fix! I had all sorts of spinning on the rims issues pushing the g's I was and then the aqua net trick was the fix
Old 09-25-2009, 08:25 PM
996FLT6
996FLT6's Avatar
So a hair net and bobby pins are in order as well : ). Mike
Old 09-25-2009, 08:28 PM
996FLT6
996FLT6's Avatar
Seriously so in lite of the spinning do u guys actually feel car is unbalanced? Mite do that ( have a set of r6 for future events). Mike
Old 09-25-2009, 08:53 PM
LVDell
LVDell's Avatar
It's not that the car feels unbalanced but the wheel shaking in your hands
Old 09-25-2009, 09:23 PM
996TT_STEVO
996TT_STEVO's Avatar
Big problem for me also... After 2 x 20 min session on track the fronts moved 8 to 9" the rears moved 14 to 18"... then tried bead seal rubber compound did not help whatsoever... running AWD 996TT
Old 09-25-2009, 09:56 PM
996FLT6
996FLT6's Avatar
Oh **** my steering wheel did shake abit back from the track on kuhmos- thought it was the low tire pressures( did not inflate them when leaving). Thanks. Mike
Old 09-25-2009, 09:58 PM
1fastline
1fastline's Avatar
Thanks for all the great replies. I have heard of the hairspray before and will try it! I am glad I'm not the only one who had this problem. I agree with LV in that it seems to happen under braking. After they go so far you get lotsa vibe and shake in the front end, you can even feel it at lower speeds if it moves enough. Has to do with both balance and road force issues.
Old 09-26-2009, 07:13 AM
996TT_STEVO
I would be careful what you use on the bead... if you use to strong a compound it will more than likely strip the rubber off the bead of the tire. I have heard of other slicks shifting on the rim but these are by far the worst, it really is just that particular bead design on tire.
I used to spanner for MX team and you are correct hairspray is what some used for mounting their grips onto the bars, they also used washing up liquid, when both dry they act like a glue.
Old 09-26-2009, 12:12 PM
va122
va122's Avatar
you guys brake that hard?? i just trail...maybe i have more speed available. My coach says I have the max speed in the corners possible for my tires. I'll address this at our next session you can be sure.
Quick Reply: "Clocking" r6's on rims
