ATE Cayenne rotors for GT3
Back from Monticello's full course. Three pretty hard braking zones and several other ones too. Happy to report that the ATE's worked great. It is possible that I sense a slightly "softer" feel or perhaps less initial bite but I can't be certain if my senses are accurate enough. Even if that were true, I quickly adjusted and was pleased with the results. I see no reason to run anything else. We will see about wear but Dan Jacobs (from whom I bought these at the TireRack price of $ 130 each) believes that they will last twice as long as the cup rotors. Here's some pix after the event.
On the weight question...I didn't weigh them per se but purely judging by lifting them, I'd say they weigh the same as the cup rotors. No gain, no loss.
Cheers,
Fellows,
I bought a set of 6GT3 fronts -- $260 for 2 -- from Dan Jacobs, Hary Dog Grrrrage -- they arrived yesterday. I'll be putting them on the car in June to be ready for the Metro Summit Point 2-day later in June.
I'll give a report after that event, and if anything comes up before then.
Fellows,
Maybe have you a pic?
Fellows,
Looking forward to more feedback from people who are using these. My current cup rotors are going to be the last set of these cracking wonders I'll ever use.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Cheers,
AllanJ- u be surprised to know slotted ones crack too on the slotted grooves. Didn't believe it til I saw HolgerB's slotted rotor though not quite as thru and thru cracks as drilled. I have the cup rotors as well- they show little cracks in just one day of track : (. Regards. Mike
I was going to get a set of Deman rotors until I heard about these ATE ones. Cheap is good as long as they work reasonably well.
Cheers,
