996 GT2/GT3 Forum 1999-2005
ATE Cayenne rotors for GT3
Old 04-19-2011, 12:07 PM
  #166
marc a
marc a's Avatar
Chuck,
The car is track dedicated, former GT3-S class. The brake conversion will be done in time for my trip to VIR in May with FSR. Pads will be RS-29s or PF97s. The 29s came with the calipers and are almost new. The 97s are new. I need to have someone look at the Pagids before I decide because they look funny to me. I am not familiar with Pagids as I have only used PF and Hawk in the past. I did post pictures of them on the racing board and they said the pads looked normal. If they are, then I will use them first.
I will update with specific rotor weights, pads, etc after the event.
So I see that KJ was ******* you at VIR . . . it will me my turn to dog him in May
Marc
_____________________
'00 Audi TT
'99 996 (Wife's ride)
'86 951 LS1 (C-2)
'77 911 3.2 (C-1) Gone but not forgotten.
3.2 Conversion and 915 Rebuild Home Page
The 958 Conversion
958 Track Video
PCA National Registry of Instructors
Old 04-19-2011, 01:04 PM
  #167
cfjan
cfjan's Avatar
Ordered a set of these ATE rotors from Amazon.com. I don't need it in a hurry, so I can wait.. later this year, maybe at the end of the season, I will take out the front PCCB and replace them w/ these ATEs... then I can run the pads down a little bit more instead of taking them out at 50%...
Old 04-19-2011, 01:42 PM
  #168
FFaust
FFaust's Avatar
Rotor weights today:
- ATE Cayenne 350mm (going on): 27 lbs
- Brembo 2-piece floaters (coming off): 21.5 lbs
- OEM Porsche GT3 drilled: 24 lbs
Last edited by FFaust; 04-20-2011 at 09:05 PM. Reason: Add actual weight of OEM disc
Old 04-19-2011, 06:33 PM
  #169
FFaust
FFaust's Avatar
Next set for me will be Girodiscs as soon as negative cash-flow eases a bit (due to weight alone).
Old 04-19-2011, 06:48 PM
  #170
M3EvoBR
M3EvoBR's Avatar
I Just checked 119.00 for the left and 80 for the right 1 piece of each one instock.
Old 04-20-2011, 06:34 PM
  #171
IMGT3
Former Vendor
IMGT3's Avatar
Ate CW34123 Front Left and CW34124 Front Rights (Cayenne S) 350mm rotors are in stock! PM me for details and Discounts. Chuck
Old 04-20-2011, 09:12 PM
  #172
FFaust
FFaust's Avatar
Chuck, increase value added by drilling the positioning screw holes into the ATE discs. Easy to do, and makes these an even more direct replacement.
I bet you sell a tonne.
Old 04-20-2011, 09:24 PM
  #173
atr911
atr911's Avatar
Why not just replace the brembo floaters with brembo? Are they insanely pricey?
Old 04-20-2011, 10:11 PM
  #174
FFaust
FFaust's Avatar
Yes, and the hats are a bit worn too.
Old 04-21-2011, 01:26 AM
  #175
IMGT3
Former Vendor
IMGT3's Avatar
I'm impressed! you do good work! I'll get my prices low and you create a template and we make everyone happy. what do you think?
Chuck
Old 04-21-2011, 09:21 AM
  #176
FFaust
FFaust's Avatar
Chuck
Thanks, but everyone has a template in the removed disc. Just that not everyone might want to do this, or feel up to it (not that it's very complicated).
I used an old cup hub with studs and dropped in in from behind the disc, it was nicely centered, and just drilled a pilot hole through both.
Now, getting the ceramic plugs to stay put while reassembling, that was another story, sheesh.
Old 04-21-2011, 09:47 AM
  #177
IMGT3
Former Vendor
IMGT3's Avatar
Cheers! creative thinking on your part. Did you have any difficulty with drilling or counter sinking for the screw heads? Is this the first time you've used these rotors? Chuck
Old 04-21-2011, 11:35 AM
  #178
IPguy
IPguy's Avatar
Another "value add" might be finding an aftermarket 350x28 disc from another Pcar that will work on the rear. I think someone mentioned that the Panamera uses a 350x28 disc, but I don't recall more than that.
Old 04-21-2011, 11:48 AM
  #179
AllanJ
AllanJ's Avatar
I drilled a little hole in my ATE rotors the first time I used them and it was easy. Cast iron is soft. I posted the drill bits here a while back, but I used 1/4" for the through hole and some larger bit (I can't remember) for the countersink. Now that I'm running studs I'm not bothering with the little hole.
Cheers,
Old 04-21-2011, 01:41 PM
  #180
IMGT3
Former Vendor
IMGT3's Avatar
always happy to try! I know the rear rotors are buggers. Chuck
Quick Reply: ATE Cayenne rotors for GT3
