Can't fill gas tank
Can't fill gas tank
For the past few months I have not been able to get a full tank of gas. The gauge reads 7/8 at best. From my recorded mpg and the gallons accepted, seems that the tank will not accept the last 1-2 gallons. Is there a vent or some such I could check?
There is a charcoal canister for the fuel tank for emissions reasons but I doubt it would be the problem. There was an issue with fuel lines inside the tank on early build GT3 and some GT2? See the thread below.
https://rennlist.com/forums/996-gt2-...highlight=fuel
Mine also does this on occasion when it is either hot outside (+100 degrees) and the car has been run hard, or I get the random gas pump. Haven't found anything wrong with the car and all I need to do is stand there and hold it tight into the car to get it to fill/overfill.
I've been having the same issue. Normally stops at 3/4 tank, occasionally 7/8 or even full. I already had the fuel level sensor replaced once under CPO, but it's still happening. I'm going to try a few more gas stations and see if that makes any difference.
Mine always pukes when I fill it from my gas cans at the track when the tank gets about 3/4 full. If I start it and run it for a while, it somehow resets and will allow me to fill it the rest of the way
Mine does the same thing. Seems to go in waves--does it for awhile then fills up all the way for awhile. I've always assumed it was the pump. Sometimes if you push the nozzle or change the direction a little, it'll fill more in the tank. The irony is that when it works properly and fills all the way, even a very small amount of topping off will overflow the tank.
Joe, that must've been your email to Joel Riser.
Mine is a consistent problem at any/all stations, whichever pump I use.. Good news is I can't get it to overflow. That's another way that I know it's not filling.
Yeah, I asked Joel, he directed me to Peter at the dealer. Trying a little DIY before taking it in.
Now that I think about it...a friend is storing his Boxster S (986) at my place while he does a remodel on his house. Took it for a drive this weekend and gassed it up. It did the same thing. Pump stopped at 3/4 full and I eventually got it 7/8 full.
I have had the same problem, on two occasions. Now I always check the gauge prior to shutting off the pump. If it does not show FULL, I just add more gas, with caution......
So far no overfilling.
Fuel came out of the filler on me once too. I was doing the fuel with fingers on trigger and it clicked off. I decided to give it just a bit more fuel and it over flowed a little. I cannot remember if the tank was even full.
It was a Chevron for me.
One time I took an extra 5 gallon can and tried to add additional gas when needed, what a PITA, kept overflowing. Had to poor it Very slow, otherwise it was a mess.
