996 GT3RS suspension
I have completed the install of factory 996 GT3RS suspension. The 996 RS version had drastically revised uprights all all corners, different springs, shocks, control arms, ext....all homolagation parts found on the 04 GT3 RSR. It has transformed the car, the car is super low, even at this height the suspension is now in more correct geometry than with the stock stuff at normal ride height. Note the position of the front calipers rotated down towards the bottom. The car is almost perfect with all factory CS parts, A/C delete, and Radio Delete.
A/c delete?
My GT3RS has both radioCD and A/C as fitted at the factory - I cant imagine driving 450 miles to the ring without radioCD - or driving the ring/Spa/Monza without ac in a helmet with air temperatures at 27/30 degrees!
I even fitted the rear speakers to round out the sound quality!
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Dont forget to fit the carbon fibre rear wing - and some decals on the side.
Very nice. Did you fit the bump steer adjustable toe links from TRG etc. Just thinking of putting them on my car to remove the rubber bushing and get the link horizontal for my ride height.
No I did not get the other toe links, I was thinking about the cup version. Currently it is exact to the RS spec car which sadly were never available here in the US. The car has less bump steer at even the low height compared to the car at near stock height with the stock uprights. The whole job with every part new is a little over $10K, and worth it. I love the NO radio, no A/C, having no air is not only proper true sports cars stuff, but I just dont need it on the northern west coast with the mild climate. If I want these items in a car, I drive my Turbo fluffer.
I can't really get under my car at the moment either, so keen to know whether with a higher ride height than your, my bump steer is better or worse than yours.
Also do you know if the ARB drop links attach to the dampers at the rear or the uprights as per the 997?
(I really should get under my car lol!)
Yes the car is low as hell! The bump steer of course always lessens with the higher ride height. Even at the current height the bump steer is far less than a mild lowered car with stock stuff. I dont want to build a clone RS, its more that the stock parts on the GT3 are a compromise when lowered......the RS stuff is just bad ***!....gotta have it. In retrospect I should have just imported an RS. The engine is stock, as is the gearbox except the CS clutch. The car is in serious need of gearing however, that is next. The extreme negative camber can be lessened by machining the two piece rear control arm and sucking the bottom of the wheel assembly inward.
BTW, my suspension is set to standard factory spec for the street and it's not too low at all.
You can get the real thing here inthe US but you just have to be willing to pay for it. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I think there are 3 ro 4 that I have heard of.. Here's one for sale now in VA
http://www.synergyracing.com/sales/index.cfm?cid=16451
