996 GT2/GT3 Forum 1999-2005
PFC direct drive rotor weight vs. Cup rotors
Old 04-06-2008, 07:21 AM
  #61
Yargk
Yargk's Avatar
How many days do you get out of the pads?
Old 04-06-2008, 06:19 PM
  #62
iLLM3
iLLM3's Avatar
Rob in VA, where are ya' buddy hah... I posted a pic for you of my rear rotor!
Old 04-08-2008, 02:51 PM
  #63
iLLM3
iLLM3's Avatar
Update?????? Would love to hear more impressions as I am in need of some front rotors soon!
Old 04-08-2008, 03:13 PM
  #64
Rob in VA
Rob in VA's Avatar
Sorry Martin.. been busy...
From the picture they are definitely at least two piece rotors. I don't believe they are Cup rotors. You can call a shop like farnbacherloles.com and ask them or maybe ask Ruf what they are? I wouldn't go changing them just for the sake of changing them. Once they do need to be changed PFC seem to be the way to go.
Old 04-08-2008, 03:40 PM
  #65
iLLM3
iLLM3's Avatar
My shop said they are going to find out exactly which rotor's they are,a ll I know is they are damn light for their girth!
I probably will just get another set of front cup rotors, although I probably should get a floating multi-piece like the rears, only thing is I want them to last a bit, and don't want to deal with the expense of the drilled rotors cracking!
Thanks though, I guess i'll make up my mind soon enough!
Old 04-08-2008, 04:01 PM
  #66
Z06
Z06's Avatar
I probably will just get another set of front cup rotors, although I probably should get a floating multi-piece like the rears, only thing is I want them to last a bit, and don't want to deal with the expensive of the drilled rotors cracking!
The slotted AP racing two piece rotor will be the longest lasting, used in the ALMS, I have no problems using these with the Porsche Cup race pad.
Old 04-08-2008, 04:12 PM
  #67
iLLM3
iLLM3's Avatar
How much do they run, can you use the pagid's with them?
Old 04-08-2008, 07:04 PM
  #68
Z06
Z06's Avatar
The rotor is a direct replacement, you can use any pad you like..I use the Porsche Cup race pads P-50 P-40...I have also used the Pagid Black 14.
Wrightwood makes them... I bought them from TRG.
Old 04-08-2008, 09:10 PM
  #69
spare tire
spare tire's Avatar
You guys have been swindled by the biggest marketing scam known to man. All this arguing about the lightest rotors. I purchased all the talked about brands and put each of them in my hot tub and not one of them floated. There is a sucker born every day!
Old 04-08-2008, 09:57 PM
  #70
Rob in VA
Rob in VA's Avatar
haaa... funny man.
Old 04-22-2008, 06:42 PM
  #71
Rickard 993 Turbo
Rickard 993 Turbo's Avatar
Originally Posted by g3tcs
With mine I have never had a problem with the brake dust, wet or dry, no difference to the Pagid RS29's.
Have just ordered some 01's so cannot comment on differences to the 97's.
I have sent you a PM, can you send me in the right direction where to buy PFC in the Uk for this price
Old 04-22-2008, 06:53 PM
  #72
DanH
DanH's Avatar
Fearnsport. Great guys and done a fair bit of work on my car including cup linkage, diff rebuild etc.
Old 04-23-2008, 05:36 AM
  #73
Rickard 993 Turbo
I will email, thanks
Old 04-23-2008, 03:17 PM
  #74
Rickard 993 Turbo
talked to fearn sport today PFC 01 cost £450 long way from £148 f+r
Old 09-30-2008, 02:44 PM
  #75
Phokaioglaukos
Phokaioglaukos's Avatar
I am on my second set of AP Racing discs using the same hats. I like the durability of the discs, but the bobbins that connect the discs to the hats wear badly, needing replacement before the discs. Anyone else have that issue? The availability of replacement discs also seems to be reduced. Are the ALMS folks still using these?
Quick Reply: PFC direct drive rotor weight vs. Cup rotors
