What oil for GT3 gearbox???
GT3 player par excellence
Most dealers do not stock PTX for just GT2, 3's, and turbos. They use whatever they have.... I had my dealer R/R the gear oil (5700 miles) when they did the second RMS using Mobil 1 75-90 Delvac that I got from Lufteknic.
Dell,
Last I knew you were getting PTX pumped from a drum into your own container from the dealer. What changed?
I use the Delvac as well from Lufteknic:
http://www.lufteknic.com/Merchant2/m...ode=lubricants
hmmm, if you don't hear slight groans as you turn out of your driveway or cycle around parking lots and such, then I wonder whether your chosen lube has the "correct or approved" friction modifiers for the diff? The grunts and groans are generally a considered indications of a functioning limited slip with correct or OEM lube in the box?
Dave, I was being a bit facetious
It's just hard to hear over the bypass pipes!
Yes, I do hear the grinding, banging, rattling, sounds of the diff when I back out the driveway. On the track? Not a chance
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
