996 GT2/GT3 Forum 1999-2005
Traqmate users....do you have the RPM input?
Old 11-07-2010, 11:04 AM
  #46
va122
va122's Avatar
IRRC it's 0...
Old 11-07-2010, 11:40 AM
  #47
himself
himself's Avatar
Originally Posted by mkk62
bringing up an old thread i have had a previous carrera s with rpm without problem on traqmate...my gt3 with same port and #1 cylinders on set up shows very high revs like 18k...anyone know the proper # cylinders on the display unit setup? thanks
If you only have one data lead, it is probably 1 instead of 6. Since 6 is the max you could have, just keep reducing from 3, 2, 1 until you get the right RPMs.
-td
Old 11-07-2010, 10:23 PM
  #48
mkk62
mkk62's Avatar
thanks and stupid question,,when i have the data still on the DU and change the # on cylinders on DU setup , will that change the rpms on the data or do i need to record another session with the new # of cylinders to see a change?..thanks
Quick Reply: Traqmate users....do you have the RPM input?
