Lift Recommendation for 996GT3 & 964
I have the track bug, and now want to take on the maintenance of both my PCars (964 Speedster and 996 GT3). Unfortunately, I have a small one car garage which houses the GT3 while the Speedster remains in storage. I'd like to add a lift to this low ceiling (8"7") one car garage so that I can do minor maintenance (pad, rotor, wheel & oil changes, etc.). As my garage already has build in cabinets, stained wood workbenches, epoxy flooring & framed Porsche pictures, I would like the lift to be minimally intrusive. Being able to lift the car 3 feet off the ground would be ideal. Any recommendations?
I have been looking into scissor lifts, and might go that route. I really like the Bend Pak LR-60 as a compromise ($1500) due to it's low cost and apparent sturdy design. What do you think? Here is a picture that I found in a search on Rennlist (Greg D's lift & car):
Thanks,
-B
Thanks,
-B
I really like scissor lifts for areas with limited space. They are simple to put in, simple to set up, and easy to use. If you had more space, a 4 post would be the better choice but they are a PITA to set up and most require a crack-free floor and high current AC.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Perhaps these might give you some ideas/options:
http://www.ultimategarage.com/Tools/lifts.htm
http://www.revolutionlifts.com/midLow-rise.asp
http://eagleequip.com/page/EE/CTGY/LI-LM
http://eagleequip.com/page/EE/CTGY/LI-SC
http://www.werther.com/werther/auto/lifts/C120.htm
http://www.werther.com/werther/auto/lifts/stratosr.html
http://www.werther.com/werther/auto/lifts/s36.html
I had (sold and am buying back) the Eagle Equipment mid-rise lift
http://eagleequip.com/page/EE/PROD/LI-LM/602-002
I highly recommend it, and the price has come down quite a bit since I bought mine near 2 years ago. Makes all the "get track ready" work much easier. I don't go to the track with a sore back anymore.
That's what I was concerned about as well... I see that some people use 2x6s or the like to "raise" their PCars a few inches as they drive over the lifts... Doe you guys do that?
One other question - do scissors lifts lock? I am not confident to get underneath my car and have to trust only the pneumatic or oil system...
Thanks-
-B
Thanks-
-B
Thanks-
-B
Thanks-
-B
The scissor lifts do have safety locks. Some have three positions, others six. The Eagle unit I had was a 6-position one.
I'm probably going with one like the one joe rec'd. Looks like a great compromise for those people that can't or don't want a 4 post/2post lift in their garage.
If you have 11foot ceilings or higher... it is hard not to consider one of the 4post lift where you can not only park the car up in the air, allowing another vehicle to park under it. But to also use the add-on hydraulic jacks that lift the car up off the lift platform for service work.
The low rise scissor lifts are a great compromise for servicing your car, especially when your ceilings are under 11 feet. They do sit up high on your concrete and you either need to build little ramps around it for your car or sink it into the concrete.
I have the ceiling clearance of 11' but hte 4-poster would be better if I had a bit more lateral room in the garage since it is a permanent iinstall. I am going to probably do the sciccor as a great compromise. I am TIRED of lifting a side at a time for service to prep for the weekend DE's.
Originally Posted by LVDell
... I am going to probably do the sciccor as a great compromise. I am TIRED of lifting a side at a time for service to prep for the weekend DE's.
Originally Posted by rabjohns
Looks good. No height probs with the GT3?
It wasn't on my car that I found this out. Unfortunately, it was a friend's,
Originally Posted by ltcjmramos
I noticed this question, but forgot to reply. In my case, I do have one limiting factor. When my roll-up garage door is closed, I can take the scissor lift to its full height. When the garage door is open, I have to watch the lift height as the roof of the car will hit the garage door.
and, fortunately, it was a DentPro fix that my insurance company covered. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
