Laguna Seca Resurface
GT3 player par excellence
yes, caleb, it has been resurfaced.
it is faster for most ppl/cars.
i am sure you were in 138-140 region this weekend.
good to see ya!
good to see ya!
Yep, I was just watching the Touring and GT races that I recorded from a couple weeks ago and they were commenting on how they are going to resurface the entire track as they made some "errors" while paving it and it was too bumpy. Oh well. Somebody screwed up.
Good to get back out there. Upper end of that range is where I ended up. Sans wife perhaps I could go a little lower. It definitely seemed faster to me and I thought it was already smooth. Hard to imagine it getting even better. When's your next event?
SCCA ran there a couple of times, most classes are 1-2 seconds faster.
While bumpy, the track is VERY sticky and most complain about understeer with the same setup they used in the past.
I've been told by local track officials that they are indeed going to repave the track. Rumor has it that the contractor who did the job has done 2 other tracks and they have the same issues and are suing. However, this is just a rumor.
my nexe event is SP 11/12, then TH 11/13, followed by 11/23 at SP again. then car goes for annual maintenance. wont be out until february 2007
Mooty, who's at TH 11/13?
if you want to go, email me. i'll send you info. plenty of space.
most drivers are fast and courteous.
no run group, you drive until you can't move anymore.
has corner worker and ambulance.
most are BMW cca racers.
The only place that I noticed that was a little unsettling was in 1. Car would get a little light and hit a ripple or two right at the apex and the back end would just tweak a little bit to the side. Nothing ever came of it, but it definitely felt weird. Could have been there before and I never noticed it - usually the track entrance lane isn't coned off so you can get a little more to the inside and maybe that was it.
