996 GT2/GT3 Forum 1999-2005
Slicks/Tire choice
Old 08-01-2006, 01:05 AM
  #31
GT3 Nut
GT3 Nut's Avatar
Unfortunately the "cup" slicks do not come in the right size for the rear for the street car. The 27/68 size is too tall and messes up the ABS bigtime.
Thanks for the heads up on the 7A/8A though.
Old 08-01-2006, 02:18 PM
  #32
Biker
Biker's Avatar
Will Dunlop M 285-680-R18 on the rear and MS 250-640-R18 fit and work on the street GT3? According to these posts, they won't. But, I have "won" a set of these Dunlop tires. These are Cup Car tires and I am worried that the fronts won't fit and the ABS will not work properly. I have the stock wheels and chamber on this car.
Old 08-01-2006, 02:50 PM
  #33
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
Stock camber and slicks are incompatible. Slicks require lots of negativer camber to deliver their additional performance. Unless you go to around 4 degrees negative you're wasting your money. Stock camber is not even enough for the DOT R compound tires to work correctly. The Michelin Cup wants around 2.5 negative. Stock is around neg 0.5 to neg 1 degree.
Best,
Old 08-01-2006, 03:15 PM
  #34
Biker
Biker's Avatar
Bob, thanks, I can do the camber, I know what you are talking about. But; will these tires work then?
Old 08-01-2006, 03:22 PM
  #35
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
Not with your street ABS. Just ask Matt E. (GT3 Nut) about his experiences.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 08-01-2006, 03:25 PM
  #36
Geoffrey
Geoffrey's Avatar
Of course, you can always install the ABS rings with less teeth on the front end and run the larger 680s in the rear.
Old 08-01-2006, 03:30 PM
  #37
Larry Herman
Basic Site Sponsor
Yeah, but the rings are part of (or pressed onto) the stub axle, and so you have to remove the nut and stub axle to do so. Not a huge job, but probably not worth it to just try the slicks. If you were going to run them permanently though.....
Old 08-18-2006, 03:51 AM
  #38
GT3 Nut
GT3 Nut's Avatar
Where do I get the ABS rings with less teeth? PMNA? Are they compatible with street ABS system? How big of a job is this?
Quick Reply: Slicks/Tire choice
