New Fabspeed GT3 Intake Kit - FINALLY!
Former Vendor
INSTOCK!
$579 or $695 with BMC filter SHIPPED.
GT3 cars gain +10.6 HP & 7.5 FtLbs Torque. Fits all GT3 cars worldwide from 1999 ROW to 2004/2005 USA and European models
1) Allows unobstructed airflow to the engine for a MAXIMUM POWER!
2) More airflow than any other system available anywhere in the world.
3) COLD AIR is force feed to the engine's airfilter by the stock FAN and snorkel. See the photo above as the FAN blows cold air directly onto the airfilter and the intake snorkel dumps cold air directly to the filter.
4) Easy to install and saves weight. CNC air craft machined with T304SS drip edge.
5) Retains stock MASS AIRFLOW sensor plastic grate and location for maximum power and no Check Engine Light.
6) More sports car sound and CUP car sound!
7) Reuse either stock OEM paper airfilter or use a K&N and or BMC F1 airfilter.
8) Easy to install and complies with emissions and factory Porsche warranty. Saves weight and looks cool and is the best and most productive upgrade for the GT3.
LINK TO DYNO CHART http://www.fabspeed.com/Gt3%20Airbox...o%20Result.jpg
![](http://www.fabspeed.com/GT3%20Intake%20System.jpg)
![](http://www.fabspeed.com/GT3%20Intake%20System%20at%20Dyno.jpg)
The 1st photo show the factory OEM paper GT3 airfilter on the silver Gt3. The 2nd photo with the yellow GT3 shows a BMC F1 aifilter in the MAXFLO CUP air intake system.
The Speed Yellow GT3 showed up the the used BMC F1 airfilter. After baseline runs the only change was the installation of the CUP airintake system and the GT3 picked up
+10.6 HP & 7.5 FtLbs Torque. Fabsped system fits all GT3 cars worldwide from 1999 ROW to 2004/2005 USA and European models. We will post a dyno video up on the web soon. The gains were significant and repetable on the Dyna pack. Rafel Llopiz my customer Gt3 just cranks by bone stock GT3 cars at the track with Fabspeed Motorsport catbypass pipes, Maxflo muffler with tips, BMC F1 airfilter.........and now he added another 10+HP. Stock GT3 engine & transmission with mnay race miles.
Have a great day
Joe Fabiani
Fabspeed
www.fabspeed.com
info@fabspeed.com
215-646-4945 (9828fax)
Have a great day
Joe Fabiani
Fabspeed
www.fabspeed.com
info@fabspeed.com
It looks like this new intake does away with the sealed air box.
How can this make more power if at least some of the air being sucked into the motor is "warm" air that is in and around the engine bay?
Please explain.
Please explain.
Please explain.
Please explain.
my opinion,
The vents on the stock deck lid will always move cold air into the MaxFlo intake.
The hot air from the engine compartment flows underneath the car, it's such a bad design (increases rear lift). The 997 GT3 (a.k.a 997 SS for Super Sport or Super Soft) uses vents on the rear bumper cover to help cool down the engine heads, the obstruction on the mufflers was eliminated by going with an one piece center muffler. There is not enough room to move out the hot air from the engine, and these engines generates much more heat that the wet-sumpers, I've measured 50 degrees difference between my engine compartment temperature after a track session compared to an intensive driven 996 3.4 on the same track session.
The only downside I see on FabSpeed design is the loss of the pressurized airbox. These cars make more power with higher speeds, the RS air scoop makes it even better, that power increase will be gone and it will be difficult to simulate on a dyno. However, that power increase is effective at very high speeds, a few Hp over triple digit speeds.
If you want to see if it works for your car on your driving conditions, remove the cover from the airbox, seal the air filter edges with duct tape to hold it to the airbox, and drive.
I think this upgrade will work for autocross, street driving and most of the tracks. On the few track where this car expends most of the time on triple digit speeds, the stock airbox combined with the air scoop might be better.
If this could be used on the street car, it would be great, but it can't.
![](http://www.autometricsmotorsports.com/products/996/04_Filter_Front.jpg)
![nono](https://rennlist.com/forums/graemlins/nono.gif)
German tuners have been cutting additional rectangular openings on the left side and in the middle of the airbox cover on turbos and GT3's for years. Free of charge for the handy!
Ciao,
Johannes - I have inspected my decklid fan when it is running. It definately SUCKS in air. It is NOT expelling air from the lid. Tim
Tim,
My bad.
Anyhow I doubt that the mickey mouse fan on the engine lid would assist in providing much fresh cool air and it only comes on when the engine is very hot. I would have thought that more cool air would be fed by the louvres on the engine lid when the car is in motion. I'm cutting by airbox cover a la Manthey as per my picture above if anything at all.
Ciao,
My bad.
Ciao,
The german's idea is good if it is sealed, but without a new deck lid you still have one hole sucking in cold air from outside and the other 2 sucking somewhat warmer air from the engine bay area.
I understand that more air is good, but shouldn't it be mostly "fresh".
As for the above comment the stock lid has the air intake hole sealed with a foam gasket. I am tempted to have a go at cutting or drilling the decklid with holes ( be better to cut a number of circles as large rectangular holes may affect rigidity too much) to match those shown in the pic in the airbox, then gasketting the holes with a closed cell foam. That would eliminate hot air in the intake. Sounds so easy why hasn't it been done?
Hmmm... perhaps I should patent that idea....
