996 GT2/GT3 Forum 1999-2005
How to mount my 6-point harness?
Old 04-23-2006, 10:54 PM
Slowpoke
Slowpoke's Avatar
Default How to mount my 6-point harness?
Hey guys,
I have just bougt me some GA 6-point harnesses for my car? I found a pic of a black GT3 with some red ones mounted, hard to say exactly how it is mounted in that pic though
Security is important, so I reach out to you
Pics would be nice as well
TIA!
Old 04-23-2006, 11:15 PM
roberga
roberga's Avatar
do a site search. There are some pic on the gallery. Do you have GT3 euro seats? roll bar?
You will also need a sub strap bar. It is an easy job but important to do it right.
Old 04-23-2006, 11:17 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,884 Likes on 2,408 Posts
the usual way to mount them is to use roll bar for shoulder harness, GT3 seats have tabs on the side for lap harness, and you can get a cross bar under the seat for the crotch belt.
they absolute correct way to do it is to have the eye bolts go through the tub and put a large thick backing plate on the otherside of the tub, but that means putting holes through the chassis.
Slowpoke
Slowpoke's Avatar
Euro GT3 seats and roll bar, yes..
What gallery? Sub strap bar? Thanks!
Old 04-23-2006, 11:20 PM
Slowpoke
Slowpoke's Avatar
No holes in my car, other than the allredy existing ones
Any other ways? How do I attach the harness in the rollbar? Sub strap stuff Roberga mentioned?
Remember, I'm Swedish so go easy on me with the english explantions
Old 04-23-2006, 11:38 PM
mooty
mooty's Avatar
there's a very specific way to wrap shoulder harness onto the roll bar. i dont know how to do it, my race shop does everything for me. sorry. i am sure there are similar outfits in your locale.
substrap bar.... check it at www.carnewal.com
Old 04-24-2006, 12:00 AM
Holger B
Holger B's Avatar
It also depends what your harness looks like. Some have clips, while others are designed to be bolted in.
These guys likely have the stuff you need (search rennlist threads to see what others have done):
http://www.bkauto.com/porsche/seatmounts.php
Old 04-24-2006, 12:02 AM
mooty
mooty's Avatar
__________
most schroth comes with clips. you clip that onto the eyebolt. you should also put a cotter pin the prevent the clip from opening up during mishaps.
Old 04-24-2006, 12:56 AM
Phokaioglaukos
Phokaioglaukos's Avatar
The best guide that I have found is the Schroth manual. It's great even if you are using different belts. You can find it HERE.
I use GT3 seats, DAS Sport rollbar and Schroth 6-point, Hybrid II and Hybrid II HANS belts. The substraps mount well with the Brey Krause bar for the GT3 seats.
Old 04-24-2006, 01:23 AM
Mr. C4
Mr. C4's Avatar
Slowpoke,
If you are not sure, let a pro do it! Your life could be depending on the installation.
Old 04-24-2006, 08:26 AM
Slowpoke
Slowpoke's Avatar
Anyone else? I have the GA ones..
Thanks!
Old 04-24-2006, 10:56 AM
viperbob
Former Vendor
viperbob's Avatar
If you want to mount a fire extinguisher, the Brey Krause sub strap bar has provisions for a mount that brings it out in front of the seat.
Old 04-24-2006, 05:13 PM
ltcjmramos
ltcjmramos's Avatar
Use Brey Krause products for the installation.
Old 04-24-2006, 08:32 PM
rockitman
rockitman's Avatar
Originally Posted by Mr. C4
Slowpoke,
ditto. Hope your using fixed back seats....? GT3 or other...
I followed the Schroth instructions for my 6 pt. If your reasonably mechanically inclined, it's not too difficult.
Old 04-29-2006, 06:58 AM
DanH
DanH's Avatar
Why not just use the Porsche OEM mounts? (bar + spacer)
I'm fitting this setup with the Scroth harness today. Does anyone know the correct torque for the lap belt mounts, and whether they should be threadlocked? (and if so which threadlock?)
I know the seat mount bolts (E12 torx) are 65nm torque and no threadlock.
Quick Reply: How to mount my 6-point harness?
