Need help with sport pedals
#31
Concern about the extensions on aftermarket pedals causing inadvertant gas pedal depression while trying to brake may not be necessary. There was a recent post about fuel management with brake pedal depression and indeed that's what happens on my car. If you simultaneously press the brake and gas down without using the clutch, the engine disregards the throttle input. Of course, as soon as you let up on the brake you get full gas back again (very jerky). Also, heel and toe ability is not upset with this feature so the fuel management must recognize when you have the clutch in and are heel / toeing versus when you have the clutch out. Personally I'd rather not have any "help" from the fuel management but what can you do... Cheers.
#33
Chris,
Don't know about the 944 Turbo. I just sold it yesterday and never tried it out before that. Next time I'm in my GT3 I'll check again but I'm pretty sure the engine cut to idle as I put on the brakes. Check and let us know if yours does the same.
#35
Originally Posted by Phokaioglaukos
For the Ultimate Pedals product, which gas pdeal are you using, and how are you using it?
#37
Originally Posted by MJones
Why is it when you look at the GT3's at the Rolex garage area the stock pedals seem to be the prefered set-up?
Seriously, for those of us that have narrow feet,
I think the brake pedal is too far from the gas pedal.
#38
