Harness Users, How do you disable Gong ?
How do you harness users disable the annoying 'Gong' When using the racing harness? Or is there no way ? Does one have to route the 3 point belt behind the seat and connect it there ?
Robin
Robin
In the earlier cars, pre 2004, you could make a plastic tab shaped like the seat belt buckle to turn off the seat belt light. This did not work in a friend's 2004 GT3. YMMV. You can route the belt behind the seat like you said or go to the junk yard and get another metal seatbelt tab. I believe the Audi ones are the same size as the Porche's.
You can also disconnect a plug beneath the bucket seat. my dealer did it for me, but I have to say I don't know if any other functions are disabled. No problems so far for me.
Robin
Robin
Robin: Call Mike S., it can be done. He did it on my car -- I just don't know the exact details.
Karl
Here's a screen shot taken from one of the GT3 / Nurburgring movies out there. Note the Seatbelt light. That you probably have to live with, the gong would drive me crazy, & sitting on the 3 point would'nt work either.
![](http://forums.rennlist.com/upload/seatblt1.jpg)
Robin
Robin
Originally Posted by Karl S
I don't think that works on US cars, it trips the Air bag warning light for some reason. If you have a wiring diagram and some electrical skills, you can solder a resistor with the proper value (I think it is 200 ohms) across the proper pins to fool the DME to think the belt is always buckled.
Karl
Karl
Still plays with cars.
until someone has a better way I simply wear my three point belt over the harness. I bet the dealer can turn the gong off with his OBD2 gizmo, The gong is a feature of the 2004 cars, my 2002 GT2 does not do it.
Rgds,
Rgds,
