0 Cam deviation
0 Cam deviation
Durametric and PIWIS showing a zero value. No codes. Anyone see this?
I am seeing actual values so suspect the ECU may be bad
Basic Sponsor
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Loren
Thank you. I know it's unlikely but have to wonder. The car was running fine-had some track days and then abruptly not. Removed the engine,verified cam timing.
Replaced both sensors and the oil seal rings and retimed but that had no effect. It was flashed but many years ago. And yes the five plug unit.
Next step is to check continuety from the plugs to the dme. Then with a magnifing glass look at the dme pins. I had to replace all my o2 pins in the harness plug because they were spred. If all that looks good send it all out to ecudoctors and have them verify that its all working.
Basic Sponsor
Also what car r u working on? U posted in both the 996 and the gt3 sections and u have given us zero background info?
