PCCB For Track -Update
#121
Still plays with cars.
Mark, the $4,184 price is still less than half the price of a new one but still too expensive considering how long they last - or don't last.
#122
Basic Site Sponsor
Basic Site Sponsor
Originally posted by Mark GT2
.....I just wanted to have a fully functional set in the event I ever need to put them back on to sell the car.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
#123
Technical Guru
Originally posted by Steve in FL
Someone should contact Sunset Porsche with the PCCB rotor parts numbers and find out exactly what dealer cost is.
The 15% handling charge is already factored into the price, I didn't call just found the offer online.
#125
Originally posted by brh986
Is that for just one rotor? "PCCB Brake Kit" sounds like more than just one rotor.
Granted, this kit is for the C4s and TT.
PCCB's at Suncoast
#126
Bob,
To change to the steele rotors?
Can i just install a steele gt3 rotor on the front with the stock yellow caliper?
For the rear i need to remove the stock caliper and replace it with a caliper designed for a smaller steel rotor.
Is there a caliper for the rear that will except the steel rotor, with the caliper in yellow? or will i have a yellow front caliper and a red one on the rear?
Is there a aftermarket 2 peace rotor that will bolt on the front and the rear with no caliper change, i have had excellent results with the alcon and brembo rotors in the past and would like nothing more than installing them.
#128
Z06
1 - Yes, the front steel rotor works with the PCCB Yellow Caliper and even uses the same pads.
2 - The rear caliper for steel is different and yes, it is red. It's made to fit the 330 mm rear rotors which are 20 mm smaller than the PCCB rotors. I'm painting mine yellow before install. This is a trivial thing to do.
3 - I have seen a post on this board describing a Brembo GT kit which may meet your needs. I am using the Porsche kit because I want to be able to buy rotors from any dealer in a pinch. By the way, the regular GT3 rotors may be Brembos - Viken will know, (he knows *everything*).
Best,
Best,
#129
Bob,
Thanks,
I went to the dealer today, and i guess it sunk in, when looking at his screen,
$10k plus garage discount,
$12k list for one pccb rotor x 4 = crazy money!
The price for a stock rotor is pretty good, i brought home the part numbers and list price for the rotors and rear calipers--$704.50 per caliper.
GT3 front rotor 996-351-410-91-- list $310.61,
GT2 front rotor 996-351-410-9h-- $1271.17,
That is a large difference!
How are you going to paint the rear rotors, i know it's not a big deal, but why not have them the same.
Thanks,
#130
I understand that you can also buy rotors for the GT3 Cup cars thru Porsche Racing at $150 each.
I was told they are the same size, but I don't know that for fact.
#131
Z06 - Not sure I understand the post - GT3 front rotor $310, Gt2 front rotor 1,271??? Sounds like the list price for a GT3 front rotor ($1271) and rear rotor $310 in C$. Am I right?
Go to any place that sells car parts, import "tuners" and the like and buy a can of caliper paint. Spray on after masking off the parts that should not be painted. Install. That's all there is to it. Changing pads is harder <grin>. The kit to change from PCCB to GT3 cast iron is about $6K Canadian including new pads.
Mac - I was told fronts were 280 - 150 sounds alot better! Z06 is quoting Canadian dollars by the way.
Regards,
Regards,
#132
Bob,
Rear gt3 steel rotor 996-352-405-00 $251.
these are the prices the dealer gave me,
Is there more than changing the rear calipers, front and rear rotors and pads
Rear calipers are $704. each,
rear rotors $251. each,
front rotors are $310 each, most likely he made a mistake $1271 each sounds more like it, these are all list price CA $$
#133
Z06 -
[quote]
[quote]
Nope that's the whole deal. I wish I could find 350 mm rear rotors in cast iron so that I didn't have to change the rear calipers but I haven't located any.
[quote]
[quote]
#134
Z06 -
[quote]
[quote]
[quote]
[quote]
#135
What size are the front pccb rotors?............ i read somewhere that they are the same as the rear............ is this true?
How does the emergency/parking brake work? ...............is it a drum style setup?
New car and i have to many questions.
