It finally happened...
Basic Sponsor
Well....it finally happened. So for those of you that think since you're GT3 is a street only car and is immune to coolant pipe failure, think again.
Since our GT3 never sees the track, I've been putting off pinning the pipes. In fact, I JUST had the conversation with our mechanic about doing them and said "we should do these at some point, we're at 100k miles now...lets look at later this summer when things die down a little" (my schedule is swamped right now). So...I was driving on a back road on the way to an appointment and all of a sudden the Low Coolant light flashes on... there is nowhere to pull over, so I ease off the gas a bit - temp was fine at around 180deg, then it started shooting up. Luckily before it hit 250, I came to a shopping plaza so I shut it off, pulled in and called AAA and my mechanic.
Coolant was all over the back of the car and dripping from the engine. Just to help cool it, I went into the store and bought some coolant to pour in. when the flatbed pulled the car up, it all dumped out! but at least it might have cooled a little while it was sitting for an hour waiting.
So...word to the wise...get your pipes done, don't put it off any longer!
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
'07 SPC
'71 914/6 Huey
'04 GT3
Bob Saville
704-395-2975
- Data Analysis & Coaching
- Drivers Gear
- Crew Gear
- Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
Bummer, but sounds like its fine all things considered. Really seems like its not really a matter of IF, but more WHEN with the coolant lines.
Basic Sponsor
So in the category of “while we’re in there”.. what does everyone suggest be replaced?
were doing:
-water pump
-clutch kit
-belt
-flywheel bolts
-rms
-engine mounts (putting in RSS)
anything else?
were doing:
-water pump
-clutch kit
-belt
-flywheel bolts
-rms
anything else?
I honestly can't believe there are still cars running around out there without the coolant pipes fixed. By now, these cars are 15 years old and all will fail soon enough. I had one blow in front of me at that track at over 130mph which could have been bad. The 991 Gt3 behind me wasn't so lucky.
GT3 player par excellence
sorry to hear that but let me re-itearate
i have had a lot of 996gt3 and 997gt3 more than your toe and fingers combined.
i have some garage queens and some track rack and some DD
they all have this issues.
just do it
even if you NEVER EVER driver the car, just do it than send me thank you gift later.
just do it
Basic Sponsor
I've had multiple Pm's for the parts list for while you are in there so I'll post it, see attached.
Gearbox was rebuilt by Copans a year earlier so some of the items were replaced like clutch etc.
The thing to remember regarding the coolant pipes is that that Porsche used glue for the coolant pipes.
At some point the hoses will need to be replaced. Maybe the hoses should be replaced proactively and pinned.
If the hoses are in good shape, eventually the glue fails. It will fail on every Mezger. I have tried my best to just treat the hose replacement and pinning as a maintenance item.
I have a 2004 996 GT3 and a 2004 Turbo Cabriolet. I had my Turbo done also, even though it never goes on track. Some of the turbo hoses were very tight and the glue was strong. Other hoses were starting to get loose.
Pranqster
Pranqster
Yeah, I have been putting this off too..
I need to find a shop that I trust to do the job. (Not the "Hey while we have the car let's swap out EVERYTHING so I can send my kid to proctologist school"" guy or the "I'll get to is real sooooon" guy )
Do it yourself with a friend, only takes a few days if you have a lift!
