Glad you found it!!! I actually did do a quick search on Autoatlanta but was unable to find that part for you. Where did you find it? Please share, as these kinds of parts are super helpful and hard to find!
Thanks! Me too
Unfortunately this wasn't as satisfying as the time I found the part number to the correct zip tie for the AOS to bank 3-6 hose (which also wasn't listed)!
This part is listed where the brake booster is. Always good to have the part number if you want to cut into it and have a spare on hand to reverse anything you install one day.
I went to a wreckers a pulled one off a boxster, in hinesight I could have pulled mine off but I didn't realise it had the part number on it (my car lives in storage so I can't easily check things sometimes).
My plan is to run my c-tek quick connect charger cables and power cables to my new dension unit which I'm going to mount in the frunk
I'm also going to mount a c-tek mounting plate on the ABS plastic cover when I buy a spare one so I don't need to cut into mine.
The idea is to mount one of these on the ABS cover and run the cables through that grommet to the battery but I wanted a spare so I can replace it if I have to. I'm also sourcing an ABS cover to cut into as well.
Also if you're wondering why i'd go to all the trouble and not just use the cigarette lighter charger... My RoW doesn't have a live one - its ignition switched
