Survey of 996 Owners
I'd like to conduct a survey of 1996-2008 Porsche owners in order to get an idea of what kinds of preventative maintenance have the most value/effect. Whether your car is healthy or if you've experienced an IMSicon failure or bore/cylinder scoring issue, please share. I will post this survey in a number of forums and compile the information in order to get some conclusive data on what works instead of just relying on circumstantial evidence:
1) The year, model, and mileage of your Porsche the last time you drove it (i.e., at the time of failure, if it experienced one)
2) Did your car experience either an IMS or cylinder-scoring-related engine failure?
2a) Did the failure occur on a racetrack?
2b) What was the nature of the failure?
3) What oil is/was used in the car?
4) Did/does the car have a LN engineering spin-on oil filter, or the stock oil filter?
4a) If the filter was a spin-on, did/does the car also have the extra magnetic strip installed?
5) Did/does the car have a magnetic oil drain plug?
6) Did/does the car have a 3rd radiator installed?
7) Did/does the car have a low-temp thermometer installed?
99 c2 cab tip. 96,808
No failures
Mobil 1 0-30 (planning on slightly heavier weight at next change. Oil seems too thin at temp.)
Stock oil filter
magnetic drain plug
does have 3rd radiator
stock thermostat
Car is a daily. Have put about 1000 miles on it in the last 2 months. Oil level does not decrease at all between oil changes. 5,000 mile intervals. Car is currently at 5700 on current change. Still at the full mark. Checked when cold.
No failures
Stock oil filter
magnetic drain plug
stock thermostat
--Two days ago--
--No IMS or scoring issue, but the engine did fail (connecting rod bolt)
--Yes, I am an idiot and money shifted the car--
--Rodbolt stretched, connecting rods gave up. Dual D-***** on cyl 2 and 3--
--DT40 on street, XP9 on track--
--Spin On--
--Not sure what this is. Time to go Google--
--Did not at time of failure, does now.--
--No--
--Did not at time of failure. Does now--
--Two days ago--
--Spin On--
--No--
1) 2000 C2 Cab. Daily driver. Owned 1.5 years. Only failure was tiptronic trans.
2) No.
3) Mobile 0-40 or Motol something.
4) Stock filter.
5) Yes.
6) Yes, standard on tips.
7) No.
2) No.
4) Stock filter.
5) Yes.
7) No.
My answers are based on the time of failure
2002 c4s - 106k km
Scored cylinders 4 & 6
No
No Clue, my guess is extensive winter driving
Mobile 1.
No
No
No
No
No
2002 c4s - 106k km
No
Mobile 1.
No
No
No
No
No
1) The year, model, and mileage of your Porsche the last time you drove it. '02 C4S, 120k+ miles | '99 C2, 105k miles
2) Did your car experience either an IMS or cylinder-scoring-related engine failure? No | No
2a) Did the failure occur on a racetrack? n/a
2b) What was the nature of the failure? n/a
3) What oil is/was used in the car? Rotella T6 in both
4) Did/does the car have a LN engineering spin-on oil filter, or the stock oil filter? No | No
4a) If the filter was a spin-on, did/does the car also have the extra magnetic strip installed? n/a
5) Did/does the car have a magnetic oil drain plug? No | No
6) Did/does the car have a 3rd radiator installed? No | No
7) Did/does the car have a low-temp thermometer installed? Yes | No
And because everyone seems to care:
8) Did the care have the original or aftermarket IMS bearing? LN retrofit @ 103k miles | Original IMS bearing
(I don't own either car anymore, but I'm still in contact with the current owners)
1) The year, model, and mileage of your Porsche the last time you drove it (i.e., at the time of failure, if it experienced one) - 2004 Carrera 2, 84,000 kms
2) Did your car experience either an IMS or cylinder-scoring-related engine failure? - Luckily no
2a) Did the failure occur on a racetrack? - N/A too risky to track
2b) What was the nature of the failure? - N/A
3) What oil is/was used in the car? - Mobil 0w40
4) Did/does the car have a LN engineering spin-on oil filter, or the stock oil filter? - LN Spin on + LN pro retrofit
4a) If the filter was a spin-on, did/does the car also have the extra magnetic strip installed? - No, planning to buy one on my next trip to the USA
5) Did/does the car have a magnetic oil drain plug? - No, installing LN next service
6) Did/does the car have a 3rd radiator installed? - No at present but will be installing one
7) Did/does the car have a low-temp thermometer installed? - No, dont have any plans for one
1) 2002 Porsche Carrera -78k
2) No - Timing Chain started disintegrating
2a) No
2b) Timing Chain started disintegrating
3) I am not sure, I believe it was like this when I purchased it
4) Not then, it does now
4a)
5) It does now
6) No
7) No
I highly recommend pulling the sump and looking for metal bits when purchasing used, this would have saved me some serious cash.
2a) No
4a)
5) It does now
6) No
7) No
1. 2000 Carrera Coupe 102,025, drive once a week or more on occasions.
2. No
2a. No
2b. IMSB (dual) had excessive wear replaced @ (100k).
3. Not sure about before but now running Mobil 0W40.
4. Stock Filter Assembly.
4a. N/A
5. Yes
6. No
7. Yes
2. No
2a. No
4a. N/A
5. Yes
6. No
7. Yes
Not sure this 'survey' will be helpful but I'll play.
1. MY99 coupe, 6 spd. 74,300 miles
2.neither
2a.na
2b. na
3. castrol 5w-40w synthetic
4. oem
4a.na
5.yes
6.no
7.next week
2.neither
2a.na
2b. na
4. oem
4a.na
5.yes
6.no
7.next week
1. MY '99 C2 - summer DD car - 137k mileage currently
2. Original motor failed on the track in '08 @ 84k mileage
Not sure of failure type
Replaced with a factory replacement in '08 (Sunset Imports - local indy installed)
3. Mobil 1 (0-40w)
4. No
5. No
6. No
7. No
3. Mobil 1 (0-40w)
4. No
5. No
6. No
7. No
Thanks for all the responses, and please keep them coming.
In response to ejDoherty: I am a frequent poster at Planet-9 and on a bunch of Facebook Forums, and I used to be VERY active at Pelican Parts. Not sure why I never frequented Rennlist (I think at one point you had to pay for membership?)
Kris Murphy -- what kind of 996 is your car? What was the mileage at the time of the engine failure, and what is the current mileage on the new engine?
