Rear Power Windows in a Cab
I have a pair of rebuilt rear window regulators that came out of my 2000 C2 cab I'd sell. I know for a fact the electronics worked on them as they tried to make my windows go up and down. Problem was cable/pulley related.
I'll never forget that DIY job. I changed them out overnight in my garage while there was a hurricane warning a few years ago. 50-60mph winds going on outside and I was in the garage in the middle of the night, drinking Stellas, sweating like a madman, and working on a convertible! LOL!
I was hoping to sell them as a pair for $700 and haven't gotten around to it.
Ping me via PM with a fair offer for one or both if you're interested.
Wow, working on your car through a hurricane is a hard core enthusiast trait I admire and respect good sir.
Five years ago, I replaced the rear passenger regulator in my 2000 Cab 4. While not easy, by following everyone's advice on this forum I removed the old one and installed the new. The same regulator went bad this summer.
Last Monday I took the current regulator out - no problem. Saturday, when I went to install the new regulator, I could not find the wire with the 6 pin connector. I looked where it should be, I looked up the tunnel through the rocker panel. To see straight down the tunnel, I removed the drain behind the rear wheel liner. I used a snake with a light on the end of it to look up the tunnel. Could not find it. There is a wiring conduit just inside the cabin running along the sill, but, it did not look like this wire originated from that part of the wiring harness.
Questions: Where might the wire have gone or should be?, If it is up the tunnel, how might I get it out? Are there any diagrams that show how this part of the wiring harness is laid out? Any suggestions?
Many thanks,
Jim
Many thanks,
Jim
Is it easy to disconnect the power wire to the window regulator? I think I see the power wire in your picture. All I want to do is disconnect the power to the right rear window regulator by taking apart as little as necessary. I am able to manually lift and lower the window by pulling and pushing it by hand and I am OK with that. If the power wire stays connected, the regulator runs on and off if I have the top down. I know I am about 3 to 4 years late to this post, but maybe you will find this reply.
Window reinstalled using eBay replacement parts for $60. Took all weekend but the savings were worth it.
