Replace a 45K LN IMS bearing 'while we're in there?'
Along with a new clutch, I had my IMS bearing replaced with an LN Engineering bearing when I bought the car way back in 2008. It had just about 40,000 miles at the time. The car just rolled over 82,000 and a new clutch is in my near future. Say one year/5,000 miles or so.
The question: Stick with the current IMS bearing, or replace it 'while we're in there?' To be honest, I can argue this either way. Interested in opinions and experience, but not hysteria.
Well, the LN site says replace every 75K miles or 6 years....you are past the 6 year mark.
If you plan to keep the car I would do the IMS solution and be done with it.
How do you know your clutch is going out? slipping? 42k on a clutch isn't that much...
If you decide to pull the old LNE IMS and replace it, it would be great if you could report back here with observations on the old bearing.
It would be really useful info for those of us like me who have LNE IMS bearings and would like some feedback on their longevity!
There is a time expiration on the bearing too, not just miles. I never remember if it is 5 or 6 years, but either way you're beyond that point.
So I think I'd go ahead and do it at the same time since even just by milage it wouldn't make your next clutch anyway.
Do it now.....you will pay much more to have it done down the road on its own. Besides, you are due based on time (not miles).
Chris(MA)....the longevity is 6 yrs 75k....that's the suggested service interval. It is clear it has not failed on this 40k/9 yr installation, but I don't think that should give you the warm fuzzies to run yours for 9 or 10 yrs, too.
40-60k seems to be the normal range with the 50-60k range what I would probably call normal. It's the ones that get 80k or more (I recall reading someone getting like 110 or 120 out of theirs ) that boggles my mind.
My Indy got 80k out of his 6GT3 and I know he didn't baby that thing, so who knows.
We replaced our first around 30k as it was out for an RMS job and it was half gone so we went ahead and did it (mileage accumulation slowed drastically shortly after so it wasn't just another 2 years before we got to the expected 60k as we expected). Similar story at 70k when the transmission was out 10 years later, though the flywheel (original) was done. So while we haven't had one in that long, we seem to be in the 50-60k range.
I'm thinking, (i) you went with a bearing you knew you had to replace, (ii) you're in there now, and (iii) the time period for recommended replacement has already passed. It seems like a no-brainer to do the replacement even though the bearing might be okay.
It's an interesting dilemma though. You bought a car with a "lifetime" bearing that never needed replacement and replaced it with one that has a limited lifetime. Of course, sticking with the original bearing came with the risk that it would shred your engine without warning while the latter one...well...couldn't it potentially do the same? The key difference is that LN warned you. Being so warned, I'd change the bearing.
-Eric
-Eric
Of course put in a new bearing! If only to tell all of us how the old one comes out...Curious to see that. It should come out perfect. That would be a single row ceramic in there? Will you now put a dual row in?
Just as a FYI, bearing degradation for an anti-friction bearing is based on revolutions, lubrication, cleanliness, etc. and not time. I do know they say after so many years.....but it really doesn't have anything to do with it unless it is sitting there rusting away.
I've never stayed at a Holiday Inn Express though, so what do I know?
I'm not saying don't replace it....just sayin' that the life of all ball bearing is proportional to the amount of revolutions, with each one it gets closer to end of life.
The only real downside of replacement is if it's installed incorrectly and has a premature failure due to installation error.
31 known failures. Just buy a new car and be done with it!
Now knowing that our original was a healthy and happy dual row I've often thought I should have just left well enough alone, but life goes on and now there is a DR Solution we can go with the next time around.
Although I seem to recall the IMS bearing is actually immersed in oil when the engine is switched off.
