996 Forum 1999-2005
My 996 is getting 12 miles per gallon
Old 06-02-2017, 09:02 PM
Splitting Atoms
Splitting Atoms's Avatar
Default My 996 is getting 12 miles per gallon
I purchased my 996 a few months ago and I have put about 600 miles on it. When I bought it, I had to replace the alternator. During replacement, it was tough to get the old one out and new one in. There is a lot of shifting and rotating to fit it under the plenum. I remember that one of the small hard plastic vacuum lines that passed to the right of the alternator got looped over the pivot bolt for the alternator. I had to wiggle it over the bolt to get it out of the way. I also pushed and pulled on the air pump hose that passes to the left of the alternator during the replacement process. Otherwise, the replacement seemed to go smoothly. I drove the car an it ran great, but shortly after I began driving it, I got the check engine light with two codes, P0410 and P1411. I cleared them and they came back a short time later. When I researched the codes, I thought that maybe I had damaged one of the air pump hoses during the alternator replacement. Those hoses are hard to get to behind the engine so I figured I would check them out when I drop the engine in the near future.
When I bought the car, it had a relatively full tank of gas and it was obvious the trip odometer was not reset when it was last filled. When that tank got to about one quarter full I filled it up and reset the trip odometer. I drove that tank to about one quarter and filled it up. Based on the trip odometer, I go somewhere around 10 mpg, which made no sense. I am getting some grey hair so I figured I accidentally reset the trip odometer when I set the time on the clock. I filled it up and reset the trip odometer again. I filled it up today and I got slightly under 12 mpg. I know I didn't have a senior moment twice in a row, so I started looking. I gently pushed and pulled on all the vacuum lines and found one of the hard plastic vacuum lines not attached.
Looking at a picture of the vacuum lines on-line, I determined it was the line that runs from the changeover valve #1 (above the alternator) to the intake resonance flap actuator (on the back crossover pipe on top of the plenum, behind the throttle body pipe). I took off the throttle body assembly, which obviously had never been removed on my car, and sure enough, I saw the tube running from the intake resonance flap actuator laying back there. Picture is a little overexposed due to the bright flashlight.
Third picture shows lines reattached.
I cleared the codes and drove the car briefly. Codes did not come back.
My first thought was damn, the engine has been running really rich and I have gas in the oil. I could not smell gas on the dip stick, but the oil fill tube definitely had a strong gas smell. Fortunately I am running 15w50, but I will not drive the car any more until I change the oil.
Hope my experience helps someone in the future.
Eric
Old 06-03-2017, 02:03 AM
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,290 Likes on 902 Posts
Once repaired, perform a system reset of the DME to clear the excess fuel trims.
Old 06-03-2017, 03:08 AM
johnireland
johnireland's Avatar
I've had my car a year and a half. Bought it with 43k miles, now has 52k. Since day one, driving around the city a lot, using manual mode a lot of the time, my 2000 C2 cab gets about 12 mpg. On the highway its much better but I never measure. The car feels right, the exhaust pipe tips show a nice even light gray, no start up issues, no running issues. Not burning any oil, change it every 5k or 5 months. I've never had a car give me the mileage it claims on the sticker. For the moment I'll chalk it up to my right foot.
Old 06-03-2017, 07:59 AM
Hurdigurdiman
Hurdigurdiman's Avatar
I have had my alternator out of the car 7 times so now I can do it with my eyes closed. However it is one hell of a job first time. You can in fact spin that large plastic intake tube around to the front for re-attachment of the small plastic tube you feature in your posting. Loosen up the two large jubilee clips and the whole thing will twist around. I have mine attached now so I can see it (at the front). When you remove your alternator for any reason again, remove the two very brittle evap lines first. You can also re-route the secondary tube to the outside of the space available for easier removal of the alternator.
Old 06-03-2017, 10:22 AM
Nickshu
Nickshu's Avatar
FWIW my 2003 C2 gets 16-18mpg pretty consistently. And I don't drive it easy.
At least that's what it shows on the instrument cluster, assuming that is accurate I have not done the math.
Old 06-03-2017, 07:08 PM
jpNcos
jpNcos's Avatar
Those tubes you broke are for the secondary air injection system... they preheat the cat in cold temps to reduce emissions.
I also broke these while doing an oil filler tube replacement.. Yes they are a pain to replace and after years of heat cycles are quite brittle and probably all needing replacement in all cars of this vintage. I plan to address them this winter.
They should not be affecting your gas mileage though long story short.
Old 06-03-2017, 07:27 PM
AnthonyGS
AnthonyGS's Avatar
Stop driving like I do and your mileage will improve.
Old 06-03-2017, 07:38 PM
Splitting Atoms
I plan on driving it when I feel like it, but don't want to put a ton of miles on it in a short time period. I plan on keeping it for a while. I also have an F250, my wife's, and both of my boys cars around, so there is always something else to drive if I want to.
I realize there may be something else going on. I bought an oil filter today and will change the oil this evening and drive it around tomorrow. I will see if the codes come back and see what kind of gas mileage I am getting. I will reset the DME as Jake suggested. I will update the thread when I have more info.
Old 06-03-2017, 07:42 PM
Splitting Atoms
None of the tubes were broken, but the one going to the intake resonance flap actuator was disconnected, so I have a vacuum leak and the resonance flap wasn't functioning. I made an earlier assumption that the check engine light was associated with the air injection system.
I also did a little reading on resonance and the intake plenum. There is definitely an impact on efficiency with the air/fuel mixture if it is not working correctly.
Old 06-03-2017, 11:17 PM
turnstile
turnstile's Avatar
I'm getting 11.5-12mpg (all city) over the past 6 fill ups, using physical gallons divided by the trip odometer. And this is driving incredibly mellow, and skipping shifts (like 1 to 3). I've done everything I can think of including; replacing air filter, cleaning MAF, proper tire pressure, not using A/C, etc. The car doesn't throw any codes, and runs incredibly well. My mechanic believes its the wheels I have on the car, and the extra width of the tires that are fitted to them. (19's w/ 305s and 235s).
Though I must add that I live in the middle of Los Angeles. My entire commute is stop and go traffic, mixed with some hills. Regardless, I never figured the car would be getting worse gas mileage than a 5,490 lbs Rolls Royce Phantom w/ a V12, but I digress...
Old 06-03-2017, 11:49 PM
cringely
cringely's Avatar
2002 996 purchased with 76,676 miles, suffered IMS failure at 100,280
Best average was on a 5500 mile road trip (brown line was average)—ave over the 5500 miles as 69+ mph with a max speed 124 mph.
Typical non-roadtrip driving was mixed between freeway and street driving. Then the average was ~23 mpg.
Granted, I am a hypermiler, but this shows what a 996 is capable of.
P.S., my computer read about 0.5 mph higher than the actual measured gas consumption
Old 06-03-2017, 11:56 PM
cringely
cringely's Avatar
and just to be obnoxious
Old 06-04-2017, 02:54 AM
wyovino
wyovino's Avatar
I get about 16 mpg around town and up to 24 mpg on a long highway drive. YMMV - literally.
Old 06-05-2017, 12:17 AM
Gbug
Gbug's Avatar
I stopped calculating after the first couple of tanks resulted in 15mpg...better not to know
Old 06-05-2017, 07:03 AM
longrowe
longrowe's Avatar
I am about 60/40 highway to stop n' go downtown traffic. Just filled up this morning and I am at 19 mpg for my 98 model
Quick Reply: My 996 is getting 12 miles per gallon
