Water Pump Replacement Data Point
Replaced my water pump preventively this weekend on my 2001 with 77k miles. To my knowledge the pump was original. It looks flawless, no degradation of the impeller. When I spin the pulley by hand the bearing sounds a little noisy, but it might be my imagination. I'd probably say it was fine to keep using. Just thought I'd share since some folks seem to think these are guaranteed to disintegrate every X miles or Y years and embed impeller parts throughout the cooling system.
Also replaced the thermostat and all idler/tensioner pulleys, all original. The new 997 pulleys are plastic and use aluminum spacers instead of steel, so a few grams saved there. The big 24mm nut on my tensioner was a little rusty so I wanted to tackle all that junk before it gets harder to remove.
Basic Sponsor
Hello - I'm attaching a link to our site's DIY tech articles in case you're going to be doing more work on your 996. The articles are broken down into sections and include step-by-step guides. Please let us know if you have any questions!
Porsche 996 Technical Articles
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Similar experience replacing a water pump this spring on an '01 986 S with 40k miles. Impeller was perfect, bearing was starting to get a bit stiff but not in need of immediate replacement. Feel better that it is replaced "while I was in there."
31 known failures and counting. After all the OCD P car crowd replaces all the parts on their cars that have yet to fail with new ones the 32nd known failure will emerge.
Selling parts for these cars is a very big and profitable business!
Just say-in.
Just say-in.
Yes. Most go well over 100k miles.
By definition you are a gambler. You bought a 996!
I used a Pierburg pump that was a Porsche part (has Porsche part number). I also replaced the thermostat housing and the thermostat, but didn't use the lower temp version (I bought TWO of these but they both were not really the 160 degree part and ran out of time).
