996 Forum 1999-2005
996 wallows in the land at slight speed 60+
Old 05-26-2017, 10:00 AM
Matt Alter
Matt Alter's Avatar
Default Alignment
I have a appt at my mechanic next week. I suggested a drive before and after the alignment so they can see whats up.
Old 05-27-2017, 02:54 AM
Porschetech3
Porschetech3's Avatar
Received 4,627 Likes on 2,099 Posts
Good..Post up the before and after alignment values so we can compare the "before" with the "after" that you have printed out now. I want to see if my suspicions are right.
Old 05-27-2017, 03:48 PM
KoB
KoB's Avatar
Originally Posted by kcattorney
Actually, it says 2004-2006 Carrera GT, but yeah, that might make a difference.
Guilty. Good reading comprehension, mediocre eyesight. Still, probably better to understand what I can see than see what I can't understand :-).
Old 05-30-2017, 09:46 PM
fuego
fuego's Avatar
Could be your tie rods as well.
Old 06-01-2017, 01:26 PM
Matt Alter
Matt Alter's Avatar
Current measurement. My tech is doing an alignment and will road test after.
I had them drive it before and they say they had the same issue.
Old 06-01-2017, 02:28 PM
rrtex1
rrtex1's Avatar
Here are mine after they re-did the alignment. Car handles better and I am not getting the wallowing as before. I don't understand them not being able to get the left front Camber in spec.
Old 06-01-2017, 04:57 PM
5CHN3LL
5CHN3LL's Avatar
If it now handles properly, that counts as a victory for you. Nice.
Old 06-02-2017, 03:00 PM
Matt Alter
Matt Alter's Avatar
New numbers.
Seems to drive better, but more high speed testing this weekend.
Old 06-02-2017, 03:01 PM
Matt Alter
Matt Alter's Avatar
Any suggestions on new shocks if I were to head in the direction? Also can I get some suggestions on what shock replacement should cost for labor.
txs
Matt
Old 06-03-2017, 01:23 AM
Porschetech3
Take the plastic panel off next to the battery, then remove 1 nut from the strut (there are 3) and see if the studs are all the way to the inside limit of the slots. If the stud is not all the way to the limit of the slot , then they just didn't adjust it, if it IS all the way to the inside limit then your strut is probably bent and would require replacement
PS: also if you look at the left front camber it was better on the last alignment (according to the numbers) and worse this time without even being moved. Goes back to what I was saying about the set-up and the equipment itself.
Old 06-03-2017, 01:36 AM
Porschetech3
New numbers.
According to those numbers that car should drive very well on the street.
Old 06-03-2017, 09:57 AM
Matt Alter
Matt Alter's Avatar
Default Driving update
I agree it does drive better. More high speed testing today. It sucks to pick your car up at rush hour. Could not open her up :>
Quick Reply: 996 wallows in the land at slight speed 60+
