996 Forum 1999-2005
Yes, another "what's that noise" post
Old 05-18-2017, 11:23 PM
Looneybin
Looneybin's Avatar
Default Yes, another "what's that noise" post
I need help from the 996 guru's on the board
I have a persistent chirping noise that is making me nuts
2003 996
The chirping only happens when the motor is cold, or has sat for 30 min and cooled some. As soon as the motor is warmed up the chirp goes away
It seems to make the noise at idle, and when decelerating from 2K rpm down to idle, and changes pace with the rpm's
I also removed the belt to see if was an accessory that was making the noise, but it was still there with the belt off
Here is a vid of the sound, recorded from the passenger side
Clutch, ims and rms about 5k ago
trim.16782532-47B1-4CB3-AC0F-DB1918D2CA07.MOV
Old 05-18-2017, 11:28 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,587 Likes on 991 Posts
Oooo, that's a good one.
Old 05-18-2017, 11:29 PM
Looneybin
Looneybin's Avatar
I forgot to add that I changed the plugs and coils 2 weeks ago, the noise was there before and is stilll there, so it's not a loose spark plug
Old 05-18-2017, 11:54 PM
Cosmo Kramer
Cosmo Kramer's Avatar
My guess is exhaust leak of some kind. When the pipes heat up it goes away. That's why it comes back after sitting for only 30 min the engine will still be hot but the pipes will be cooled off.
Old 05-19-2017, 12:37 AM
Looneybin
Looneybin's Avatar
That was my thought too, but what confounds me is that it's louder when decelerating, not getting on the gas
Old 05-19-2017, 12:49 AM
Water Hound
Water Hound's Avatar
My guess would be leaking/cracked exhaust manifold
Old 05-19-2017, 07:02 PM
steve578
steve578's Avatar
I have a similar noise on my 2004 C4S. I changed the plugs and coils a few weeks ago. While the mufflers were still off, I started up the engine and the noise was not present. I have concluded that my noise is in the exhaust system somewhere, but haven't dug any deeper. Mine is coming from the driver side.
I will take some video of mine for comparison.
Old 05-19-2017, 07:51 PM
steve578
steve578's Avatar
My chirp at idle.
Slight Rev.
Old 05-19-2017, 09:49 PM
Looneybin
Looneybin's Avatar
They do sound the same
I'm thinking I'm going to replace all the exhaust gaskets and see what happens
If you find out what is causing it, please pm me
Quick Reply: Yes, another "what's that noise" post
