CEL came back...Finally got around to getting a Durametric
#241
Maybe call Durametric ?
Your situation points to the usefulness of the cross over test harness mentioned previously.
Or use a noid light or DMM at the Variocam harness connector and run the engine to 3k rpm.
#242
"Your situation points to the usefulness of the cross over test harness mentioned previously.
Or use a noid light or DMM at the Variocam harness connector and run the engine to 3k rpm."
Did you actually make the "crossover harness"? If so, I could use the part #'s for the connectors if you've got them. I found the part number on the "coil driver" if it turns out to be that in the DME.
#243
#245
I haven't tried it yet, but it definitely on "the list of things to try"...I've been pressed for time, so I haven't been able to "go deep" yet... maybe on Sunday
#246
So, I made it up to the shop last night but was seriously pressed for time. I brought my laptop and was planning on updating/backdating Durametric, but couldn't get a internet connection . Fortunately, I was able to run a few checks - one of which crashed the program (Litronic light activations). I think there may be a problem with Durametric due to me not uninstalling before updating the program. Anyway, I'll get to that today and maybe/hopefully get back to the car tomorrow. One nice little thing I got done was zip tying the Clutch pedal "start enable" switch seen here http://www.autoatlanta.com/porsche-p...section=702-00 This switch locks the ignition out unless the clutch pedal is fully depressed. Zip tying the switch "closed" (or jumping the lugs/wires) allows you to start the car without engaging the clutch - which is really bad for the crankshaft end shims - especially if the car sits a lot (= dry shims). The funny part about this "nanny/safety feature" is that it's only present in the American cars... ***Do this mod at your own risk and always make sure your car is in neutral before starting - especially if you leave it in gear while parked*** apparently Europeans are able to handle this responsibility...
#248
Nothing yet... I've actually spent about two hours getting the shop cleaned up and all tools cleaned and put back in their proper places. In addition, my son and I got his '87 944S out of the garage as well the other night. This Thursday - Sunday I'm booked 5 nights in a row (closet R&R musician) so I won't see any shop time 'til sometime next week. In the meantime, I've uninstalled and reinstalled Durametric on my laptop so hopefully that will run without crashing, and I can get back to diagnosing the bank 1 Vario-cam actuator/solenoid.
#250
Quick update - while driving the car today, my CEL went out. Last weekend, I popped the DME/ECU out and checked the board. I didn't find anything obvious (burnt components or connections) so I put it back together and buttoned everything back up. I drove the car a little bit - probably 25 - 30 mi. and it ran fine - as it has since I've done the work - but the light remained on. Today, shortly after I took it for a drive the CEL went out... I'm wondering if it is the drive cycle since unplugging and replugging the DME (approximately 60-80 mi.)? I plan on plugging in the Durametric in a little while... will update after...
#254
#255
"Seems like this is shaping up to be one of those weird problems."
You're telling me! Granted, it's partially my work style that tends to confuse things - I rarely get large enough blocks of time to do things in a linear/scientific/controlled way. So after my last post I went back out and started the car (it was still warm) and plugged in the Durametric (which has since been uninstalled, updated and reinstalled). Wow...everything seems to be working well - I can activate the vario-cams without the computer crashing and better yet, THEY'RE WORKING! Unfortunately, at this point I can only guess as to why. It's possible that they were working all along, and the Durametric program was messed up (and uninstallation/re-installation fixed it), or that there might have been a blockage in the bank 1 actuator that has cleared itself, or removing and re-installing the DME cleaned a funky connection...
