996 Forum 1999-2005
IMSB Concerns
Old 03-31-2017, 09:16 PM
Vancouver996
Vancouver996's Avatar
I read an interview with that Charles Navarro fellow from L&N , he said his ideal car , 996 or 997 would be a 2005 997 fitted with the solution .
Old 03-31-2017, 11:18 PM
wyovino
wyovino's Avatar
To OP:
The relative hostility to your question is because this subject has been beaten to death in the 996 forum and the definitive answer is "Where did you say the fish was caught?"
Old 04-01-2017, 01:19 PM
Fracture
Fracture's Avatar
If you like the car, and want to commit to long term ownership.. spend some money on the IMSB
whether it be the Retrofit or the Solution
@ 6000 miles in 10 years, the car screams of garage queen and the
perfect candidate for some attention
however, if your not seeing ferrous particles, why would you risk waiting
for them to appear ?
no guarantee that they will, but why risk a low mileage engine to any type of damage ?
Old 04-01-2017, 03:58 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,728 Likes on 1,074 Posts
Originally Posted by Gemauro
Hi, I have a MY2005 997 Carrera 3.6L
It is an early 2005 build, so it has the M96 engine.
I purchased the car in 2015 with only 6000 Miles on the odometer, and at present it has around 12000 Miles.
I have never seen any sort of debris in either the oil pan or the filter,
Would it be wise to get the retrofit done proactively? Or has the IMS issue been overhyped to the point where people are doing it just because they are scared?
It depends on how you deal with risk. There's less than 10% chance you will have an IMSB problem. If you don't, you saved money. If you make the repair, you're out several thousand dollars. If the IMSB fails and you need to replace the engine, it could cost $10,000 or more. How do you like to roll?
More importantly, how many miles do you plan to put on the car and how long do you want to own it?
I'm a risk taker and didn't do any IMSB on my 2000 Boxster S, and don't plan to do it on my 1999 911.
Old 04-01-2017, 05:35 PM
johnireland
johnireland's Avatar
There is a new carbon fiber and vinyl composite IMS bearing coming out later this year if you can wait for it. And it can also be used in the 997.1 that have the third generation bearing and you don't have to crack the block open to install it. It uses a new liquid insertion technology that surrounds the original bearing with an exoskeletal version of the new bearing. If successful, this will replace the 997.2 and beyond engines and Porsche will go back to the IMSB design of motors.
Old 04-01-2017, 05:41 PM
extanker
extanker's Avatar
it should have come from the factory with a zerk fitting......now dat wood have been funney ......what is the best grease for my imsb
Old 04-01-2017, 10:34 PM
Woodman71
Woodman71's Avatar
Originally Posted by murphyslaw1978
It depends on how you deal with risk. There's less than 10% chance you will have an IMSB problem. If you don't, you saved money. If you make the repair, you're out several thousand dollars. If the IMSB fails and you need to replace the engine, it could cost $10,000 or more. How do you like to roll? More importantly, how many miles do you plan to put on the car and how long do you want to own it? I'm a risk taker and didn't do any IMSB on my 2000 Boxster S, and don't plan to do it on my 1999 911.
I love how your user name and being a "risk taker" contrast each other.
Old 04-01-2017, 11:48 PM
gnochi
gnochi's Avatar
Interesting. Would you mind linking a source?
Old 04-02-2017, 01:39 AM
Cuda911
Cuda911's Avatar
I think this is his source:
Old 04-02-2017, 01:42 AM
Mike Murphy
Lol, yeah, but in all fairness, I kind of played it safe buying a 99 that has the double row IMSB. Those are supposedly more like 1% failure rate. But Murphyslaw is alway around, so best be careful and cut the oil filters open every time
Old 04-02-2017, 08:40 AM
roadsession
roadsession's Avatar
It was a good April fools
Quick Reply: IMSB Concerns
