996 Forum 1999-2005
3D printed RMS tool...
Old Oct 27, 2016 | 06:06 PM
RRTEC's Avatar
RRTEC
Default 3D printed RMS tool...
Well I needed a RMS install tool. I know a buddy with a 3D printer, feast your eyes! I have no idea if this is going to work... pretty cool though. Plan to test it tonight...
Old Oct 27, 2016 | 06:53 PM
Woodman71's Avatar
Woodman71
Good luck!
Old Oct 27, 2016 | 07:54 PM
Schnell Gelb's Avatar
Schnell Gelb
Before you use it, I suggest you compare it to the official Porsche RMS tool and make some minor modifications .
This part is easily turned on a lathe using a block of HDPE or Delrin.Old school I know.
The precise dimensions are on Renntech.
Old Oct 27, 2016 | 08:45 PM
sweet victory's Avatar
sweet victory
I'd recommend throwing it in an acetone vapor bath before any sanding or light machining. Basically just find an old rice cooker, elevate the part out of the acetone, and put the lid on. The vapor acetone will just barely melt the surface and remove most of the print lines.
Old Oct 27, 2016 | 11:29 PM
RRTEC's Avatar
RRTEC
Well. It technically worked, but not really and I don't understand why... I pushed the seal on and then used the tool. The seal didn't go on even and it ended up like 13.5 in some areas. I destroyed it and pulled it out.. I then practiced and put the old and the ruined new seal back in a few times trying to practice. My last attempt I got it perfect but I don't know why. The measurements are all right. Not sure how it could go in further.
also did some measuring and I'm not sure how the seal even stays on at all. The crank surface is 24mm deep. The seal is 11mm deep and the seal is supposed to be 13mm offset from the crank face. I mean it's on the edge of falling off if you really think about it..
Ordering a new seal now.. hopefully I can get it right with the new one.
Old Oct 28, 2016 | 01:05 AM
RRTEC's Avatar
RRTEC
Ah, figured it out. Unfortunately I used the white tool and the mating surface had an imperfection. I just installed the old seal with the black tool and it worked perfectly 3 times in a row. When my new seal arrives I will pop it in there with the black tool.
Old Oct 28, 2016 | 09:21 AM
rockhouse66's Avatar
rockhouse66
Are you sure you are measuring the depth from the correct surface? I think it is measured from the outer face, not the crank face.
Old Oct 28, 2016 | 09:38 AM
RRTEC's Avatar
RRTEC
There is no way you could measure from the engine case edge. the seal would not even be touching the crank at all. It would just fall in...
Old Oct 28, 2016 | 11:50 AM
Device2's Avatar
Device2
Looks promising and a cheaper way to make the tool. If you ever want to hand out free copies I'd take one .
Old Oct 28, 2016 | 12:09 PM
rockhouse66
I should have looked at my picture first. It just sounded like you were installing the seal too deep and maybe measuring from the long location. The seal should be fully on the crank seal surface but I agree if it goes in much further than spec it would either be barely on or would just fall off the crank flange. Seems perilously close!
File Type: jpg
Old Oct 28, 2016 | 12:23 PM
RRTEC's Avatar
RRTEC
He said it took 15 hours to print.. it weighs like 2 lbs. HA!
Old Oct 28, 2016 | 12:37 PM
Schnell Gelb
A 3" pvc sewer pipe cap from Home Depot also works- see Renntech.
Old Oct 28, 2016 | 12:42 PM
5CHN3LL's Avatar
5CHN3LL
Your buddy needs to learn how to print hollow parts w/ supports instead of printing solids. The walls don't need to be more than a few MM thick; printing that thing solid was a massive waste of PLA/ABS filament and time. I like the idea, but the execution still needs work.
Old Nov 3, 2016 | 11:24 PM
RRTEC's Avatar
RRTEC
Second tool worked. On to the next task.
Old Nov 4, 2016 | 01:31 PM
Schnell Gelb
Machine it from a puck of HDPE in a few minutes.
