996 Forum 1999-2005
Why is my headlight out?
Old Sep 23, 2016 | 08:40 PM
Soaringman's Avatar
Soaringman
Default Why is my headlight out?
Ok I know stupid question, it's driver side low beam, old bulb looked fine , put new bulb in , nothing .
fuse looked fine, put new fuse in , nothing
is there some kind of compasitor relay ballast condenser I don't know about ?
Old Sep 23, 2016 | 08:42 PM
OKB's Avatar
OKB
swap bulbs with other side
Old Sep 23, 2016 | 08:53 PM
Soaringman's Avatar
Soaringman
The bulb that come out looked good and I put a new bulb in, so faulty bulb has been ruled out
Old Sep 23, 2016 | 09:24 PM
RRTEC's Avatar
RRTEC
Pretty common.... headlight switch.
Old Sep 23, 2016 | 10:21 PM
Dennis C's Avatar
Dennis C
Rocky Mountain High
+1
Old Sep 23, 2016 | 11:12 PM
mdsarch's Avatar
mdsarch
Yep, there is a panel board behind the headlight switch that goes bad.
Old Sep 23, 2016 | 11:18 PM
Teekster's Avatar
Teekster
There is a brown ground wire inside the frunk, behind the carpet. Mine was loose. Check that before you go to the trouble of replacing the headlight switch. I didn't.
Old Sep 24, 2016 | 05:42 AM
Hurdigurdiman's Avatar
Hurdigurdiman
If the faulty headlight has been removed and replaced it may have been forced back into place and bent one of the connector pins over. That's what happened to mine. I straightened or 'stood up' the bent over pin via long nose pliers and solved the problem.
