996 Forum 1999-2005
Clear headlights - need advice
Old 09-22-2016 | 04:21 PM
ZuffenZeus's Avatar
ZuffenZeus
He can still do projector style aftermarket headlights but NOT the Porsche Xenon HID based system (i.e. Litronic) which Sweet Vic makes a great point about... it's more than just plug and play if the car is the base halogen system.
Old 09-22-2016 | 08:19 PM
MoeMonney's Avatar
MoeMonney
Originally Posted by sweet victory
Litronic headlights were an option, not standard. If he has halogens, it's a lot more work than just swapping the headlights. He'll need an additional wire harness, control unit, sensors, etc.
You are incorrect. They are plug and play. Ive installed 2 sets including the ones on my own car that had original halogens.
With the Litronics installed.
Old 09-22-2016 | 08:55 PM
sweet victory's Avatar
sweet victory
You should probably mention that you lose high beams and do not have auto leveling. (Which is illegal by the way)
Old 09-22-2016 | 09:31 PM
Jason 996's Avatar
Jason 996
A small detail I would pay attention to is the gasket that goes around the perimeter. Over time it will deteriorate and cannot be purchased separately.
I noticed this to be true as well, Has anyone done anything unique to repair? It appears when it finally deteriorates to the point that allows water to enter it could damage the electronics and connection points inside.
Old 09-22-2016 | 11:41 PM
MoeMonney's Avatar
MoeMonney
You don't lose high beams. You have a low beam Xenon and High beam halogen.
The only thing you don't have is auto leveling so you have to adjust the light manually with the manual adjustments. Works perfectly. Ive done it twice and my car works like this currently.
Here is another thread from a different user who did the same as I did and later installed the auto leveling module. http://www.6speedonline.com/forums/9...-leveling.html
HERES A GUIDE TO DOING A LITRONIC SWAP.
http://986forum.com/forums/general-d...ug-play-2.html
Old 09-23-2016 | 10:24 AM
ZuffenZeus's Avatar
ZuffenZeus
I stand corrected. Thank you Moe! I was basing my comment on some of my previous cars that had Xenon HID options. If you tried to convert the halogen to Xenon projector HID style, the car would return a MIL and the headlights wouldn't function properly. Probably had something to do with the electrical load differences between the ballast based HID and the standard halogen tungsten based lights.
Old 09-23-2016 | 02:38 PM
kderry's Avatar
kderry
This is 100% false in the US. Same as the "headlight washers required with HID" myth. That's a European thing.
Old 09-23-2016 | 02:41 PM
kderry's Avatar
kderry
Originally Posted by Clark-ApexPerformance
Have a 2000 996 C4 cab and am about to get it painted and want to change
the headlights out for the Totally clear (no orange).
Have been told the 2002 -2005 will not fit. They are a different shape I am told.
I am trying to find out if these lights (clear) were made for the '99-2001 cars.
Or would like to hear what some others have done. Have seen some new clear headlights on Ebay but the price is very high.
I welcome any advice you can offer.
http://m.ebay.com/itm/Porsche-Boxste...-/291487091461
(The ad says "Porsche Boxster", but they are the same as 996)
And and on the other end of the spectrum...these are a completely custom HID build.
Quick Reply: Clear headlights - need advice
