996 Forum 1999-2005
Newbie Key question
Old Sep 16, 2016 | 02:35 PM
mk1228's Avatar
mk1228
Default Newbie Key question
Just picked up a 99 in Ocean Blue. Love it so far. Put a new ignition switch in it last night, which solved a few problems. I having an issue though with one of the keys. One key works fine. The key fob works and the key works. The other, the key fob will not work and they key itself will not start the car. It will open the door manually and unlock both doors. It fits in the ignition fine and can turn it and all the lights and radio come one, but the car itself will not start. Nothing happens at all when I turn it all the way to right.
I have looked through the various threads, but most seem to discuss a faulty key fob, but the key itself still works. Anyone have any ideas?
Old Sep 16, 2016 | 02:41 PM
mk1228's Avatar
mk1228
By the way, I did replace the battery. The fob seems dead. No LED light or anything. I can deal with a dead keyfob. I just wished the actual key would work.
Old Sep 16, 2016 | 03:02 PM
Fracture's Avatar
Fracture
https://rennlist.com/forums/996-foru...t-working.html
try this, see post 15 and beyond
Old Sep 16, 2016 | 03:31 PM
alpine003's Avatar
alpine003
You probably have a good chance that you are missing or have the wrong "pill" in your second key fob. A correct pill that is coded to the immobilizer is needed or the car will not start.
Try this: put your non working key in the ignition and then hold your working key right next to it and then try starting it. Does it start?
Old Sep 16, 2016 | 03:46 PM
DBJoe996's Avatar
DBJoe996
^^^ This
Old Sep 16, 2016 | 03:54 PM
mk1228's Avatar
mk1228
That was a good suggestion. Nothing. I think I have a dead fob and dead key. At least it unlocks the doors if I happen to be stupid and lock the good key in it.
Old Sep 16, 2016 | 04:09 PM
DBJoe996's Avatar
DBJoe996
Did you open up the non-functioning key fob to see if the RFID pill is in there? Could be missing, or it got zapped somehow. That's a trip to the dealer. Otherwise, since it works to unlock the car, maybe just a spare.
Four parts to the key:
1) Key blade - laser cut key that works the locks and ignition
2) RFID pill - that communicates with the immobilizer. Car will not start if the pill is missing, or not programmed. The RFID pill does not need a functioning key fob battery to work. Mine has been dead for years. The car is programmed to the RFID pill. Requires dealer to match the key RFID pill with the immobilizer. There is a "ring" around the ignition switch that reads the RFID pill, matching the key to the immobilizer and allowing for start.
3) Circuit board - communicates with the car to lock/unlock. This depends on the key fob battery to function, but has nothing to do with the RFID pill. Most of the time the circuit board cracks and no longer functions to communicate with the car. No big deal, use the key to lock/unlock and start. Again, a dealer visit to get the circuit board and car to communicate with each other.
4) Key fob housing - holds everything.
One caveat: I have a "valet key" that works the locks and ignition. It even starts up the car. However, it is very small and does not seem to contain an RFID pill like the bigger key fob. I have no explanation why it works, but it does. And everything works just fine with it. 99 C2
Old Sep 16, 2016 | 04:22 PM
mk1228's Avatar
mk1228
The RFID pill is in there. The who fob must of gotten zapped. I'll get a replacement eventually.
Old Sep 16, 2016 | 04:48 PM
jhbrennan's Avatar
jhbrennan
The small valet key has a transponder chip imbedded into it or else the ignition switch wouldn't recognize it and then wouldn't start.
Old Sep 16, 2016 | 04:51 PM
jhbrennan's Avatar
jhbrennan
"Dead fob" has nothing to do with the starting sequence only locking/arming. etc. Your non-working key (as others have suggested) is missing the transponder chip or it needs to be re-initialized. Dealer can do that at a cost or I believe there is a procedure that has been posted that will allow you to do it.
Just noticed that Mr. Fracture already posted the solution for re-initializing - see link in post #3 above and then go to post #15 in that link.
Old Sep 16, 2016 | 04:53 PM
ZuffenZeus's Avatar
ZuffenZeus
MK, listen to Alpine, he's the resident immobilizer expert. He actually helped Hillary with her email problems. bwhahahahahaha!!!!
Old Sep 16, 2016 | 05:50 PM
alpine003's Avatar
alpine003
Hey don't tie me with her. I work through the Russians.
Also Julian will unleash his wrath in due time as well.
Old Sep 17, 2016 | 06:13 PM
Macster's Avatar
Macster
Holding the key with the known good pill next to the other key is not a fool proof test.
The optimal position of the RFID pill is very critical and there is not much room for positional error. The RFID pill wants to be very close to where it is in the key head. There is an antenna behind the ring around where the key is inserted. When the key is turned an RF signal is broadcast from this antenna and this energizes the RFID pill and its electronic circuitry and it in turn broadcast's its ID which is received by this antenna.
That you were unsuccessful attempting to use the RFID pill on the known key to provide the signal to allow the engine to start using another key is therefore expected.
If you can insert a key and turn it all the way to right as far as you can turn any other key that fits and can start the engine the key is ok. What is lacking is a working RFID pill or one that is known the security system.
Old Sep 17, 2016 | 06:41 PM
johnireland's Avatar
johnireland
Getting a replacement "eventually" is a very dangerous game. Search around here and find the thread about a guy who did just that. And then he lost his only working key and his car became stuck in the bowels of a garage, with not enough room to get a tow truck in to pull him out and get him to a dealer. Or go see the movie Grand Canyon, about a guy who breaks down at the worst time and in the worst place. Not having a fully functional second key is being very lazy...or stupid. Get that second key now.
Old Sep 17, 2016 | 07:13 PM
Montychristo128's Avatar
Montychristo128
I thought the Russian one was called Donald?
