Intro and recomendations before DE
Country911, you have some good points to consider and to answer some of your queries:
- IMS/RMS/Water Pump replaced 3,000 mi ago
- 68,000 miles on car
- no smoke at startup
-160 deg thermostat
Not certain about the AOS but have records and will check. So there is a Motorsports version, sounds intriguing?
I do plan on a higher temp fluid and was thinking of using yellow stuff pads. With the turbo brakes as standard, I anticipate braking won't be an issue.
Yes, it will be with Carolinas at VIR - come join the fun as many drive down from the NE for one last run before winter.
