anyone know stock size of wheel lugs , 04 C4S
Thanks , I do not need them. I bought 20mm rear spacers and 48MM lugs and they seem a little short. trying to compare and make sure this is correct the size.
Received 1,902 Likes
Don't hold me to this, but I thought OEM stock length was 45 mm; therefore, if you add 20mm rear spacers, then you'll need at least a 60 mm lug.
Are you sure you want to add a 20mm spacer? Are you running 18x11 rear wheels with 295/35/18 tires?
Received 1,184 Likes
I cannot figure out the difference...OE Porsche one is 45 mm and the other 50 mm but a difference brand:
http://www.pelicanparts.com/cgi-bin/...&I1.x=0&I1.y=0
