MT Lost Reverse, then lost all other transmission gears
Not a great weekend of cars for me...
I drove my 02 Carrera Cab to dinner Sunday night, and I did have one issue with the clutch slipping ever so slightly when shifting from 2nd-3rd under hard acceleration, otherwise everything was fine drive-wise.
Sunday afternoon someone was test driving the car and then returned saying they couldn't get it into reverse. I hopped in and then when pushing in the clutch could not get the shifter to enter/engage any gear R or 1-6. From the shifter lack of movement, it felt like the clutch wasn't engaging allowing the gear to move into position in any way, even though the pedal felt normal. I read one post about the clutch cable clips and I plan to check it and the fluid level this weekend. Has anyone else had an issue like this, or know anything else I should be looking for before towing to an Indy shop for a possible Clutch replacement? (It does have 137k miles and I do not know the history of the clutch.)
It sounds more like a shift cable or clutch issue, but if it turns out to be a transmission issue, I do have a used one available.
Hopefully just the cable or clips holding them on, if so that's an easy fix.
Will do
