How fix power mirror?
My driver side power mirror doesn't respond at all when I try to adjust it. Passenger side works fine so I assume it is not a switch. Also, since it doesn't work in horisontal nor vertical direction I guess it is not likely due to faulty motors. Have also tried installing another adjustment switch without success.
What could be the problem? Is it common that wire connections detach or anything similar? Need help with problem solving here. Spring is here and I hate to drive around with glitches, even small ones
What could be the problem? Is it common that wire connections detach or anything similar? Need help with problem solving here. Spring is here and I hate to drive around with glitches, even small ones![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Go to your nearest authorized dealer, point to the car and say "my driver side mirror don't work" then go sit in the Barista Lounge and have a cup of coffee.
The passenger side mirror on my C2 makes noises, but the mirror doesn't move. I am assuming the gear teeth are no longer meshing. No big deal; I adjusted by hand. Might have my indy look at it when time to do the annual oil change.
