Studs vs. new lug bolts
I never had an issue with the lugs - my only real reason for making the swap is the issue with the boogered threads. By switching to the studs, I'll eliminate the issue (or at least make it a non-issue for a while)...
I got a set of 14x1.5 taps on Amazon for like $15. Stud install is easy, but tedious because of the double nut thing. I ended up buying a large single nut at Ace hardware for this.
If you need extra lugs, I have a few...
-td
-td
Thanks for the offer! If I get fed up with the stud install, I may come knocking.
The set of studs I got has a hex opening in the tip so they can be driven in without using the double-nut process, although I will probably have to resort to that for the two holes with imperfect threads.
That is a respectable set of lug bolts - and I like your stash of tire plug kits as well.
I see your security lug bolts are where they belong as well - in a drawer, not on the car.
I don't use them at the same time - the speed bleeders make it easier to push the pistons in during brake pad changes.
The online photo of the set of studs I got has a hex opening in the tip so I assumed that they can be driven in without using the double-nut process
In reality, the end of each stud is rounded with no opening for a hex, torx, or any other driver bit - so I'll be double-nutting it after all.
That sounds much dirtier than it will be in reality.
Studs installed today - piece of cake. The hardest thing was getting the double-nut loose after torquing the studs down. Even the two holes with the semi-boogered threads went smoothly.
Took if for a test drive, everything was perfect - and then as I was rechecking the torque values to make sure nothing worked loose, my torque wrench RUDed* all over the driveway. I took this as a sign it was time to stop working in the garage for the day, so I put it all back together and called it quits.
*Rapid unscheduled disassembly
Follow-up: After a day for the thread locker to cure and a hundred miles or so of driving, I removed a couple of the new lug nuts to see if the Loctite was doing its job - and I'm happy to report that each one I tested resulted in only a lug nut; I did not find any issues with the studs backing out or any other indications that the job was anything but a success. Woot!
Had I just wanted to ditch the lug bolts, this would have been a lateral move; since it also eliminated the cross-threading issue and will make R/R of the pax rear wheel much easier from now on, I consider this an upgrade. Very happy with the Pelican kit.
Note to anyone who does this: Make sure you do a great job wrapping the lug nuts you use for installing the studs. I boogered up the finish on two of 'em - but since they're not visible at all, no big deal.
Off to order a few spacers for the rear - now that I have the extra stud length, might as well put it to work.
Update: After less than two years, three out of the five studs on my driver-side rear wheel failed while I was driving approx. 45MPH on surface streets. I heard one let go and immediately felt the car get screwy.
I have no idea if this is common, uncommon, or a completely freak occurrence, but...it's a data point. *shrug*.
https://rennlist.com/forums/996-foru...one-wheel.html
