Alignment Newb -- What Are Settings and % Use?
Hi!
Picked up a 1999 c4 months ago, and it's been so enjoyable!![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
May you kindly share your alignment settings, and use? (Daily driver, touring, DEs %? )
Initially, local racer champ set up for track newb. Was fun, but consumed new tires shockingly quickly. (Single track day, then some daily driving -- done in few hundred miles.)
Would like to daily drive, and am thinking factory delivered wheel settings would be right for this. (?)
1. Does anyone have the "As Factory Delivered" numbers? (Just talked with PC NA, GA, and they didn't have them. Emailed classic-service@porsche.de for same.)
2. What are your alignment settngs, for what % street/autocross/DE-trackschools?
Thank you!
dan
Thank you!
dan
Hi Dan you may need to focus on google for this stuff -- Try this http://www.renntech.org/forums/topic...ignment-specs/
O_Sr
O_Sr
For AX and track with a standard suspension
Max out neg camber from and rear, no toe in the front and a smidge of toe in the back (~1/16").
With standard suspension, you cant much camber, maybe .75 deg in the front and 1.9 deg in the rear
Also it would be nice to introduce yourself in your first post and include pictures, because it ain't real without pics
without a bunch of camber, the front tires will wear oddly if you are driving hard on the track
I run this on my DD 4S, and I autocross a real lot, so the tire wear ends up evening out pretty well. Alignment, degrees per side, total toe: Front => Camber -1.4, Caster 8, Toe -0.05 Rear => Camber -2.2, Toe 0.
Stock suspension with the exception of Tarret front strut mounts (camber plates). I put them on after cracking a 2nd set of stock mounts. I'm going to add their adjustable thrust arm bushings now that those bushing are cracking on a set of replacement a-arms.
Front camber -2.8 (tarret camber plates)
Rear camber -2.3
front toe - 0
rear toe - 2mm toe in
50% street 50% track. Not putting a lot of miles on the car but if I do I'll wear the rears pretty quickly. Like inside edges corded in 4-5000 miles quickly. Its getting expensive so next visit to the shop I'll adjust to a less aggressive setup.
Rear camber -2.3
front toe - 0
4th Gear
Is there any value to going to a Porsche dealer for a 4 wheel alignment vs. going to an independent tire store?
I did a lot of research on this and in the San Antonio area I found that there's a Firestone dealer that has all the equipment, and a Porsche trained tech (his name is Jack Carrera, no joke). I have my daily driver 03 996 C2 done there and he's been great! Plus, I paid $299 for life time alignment, I've had it re-done three times for parts repair, not charged another dime. If you call around you might be able to find a Firestone dealer that has the equipment.
