996 Forum 1999-2005
Scored cylinder failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2)
Old 05-03-2016, 12:06 PM
  #31
AWDGuy
AWDGuy's Avatar
and you guys worry about IMSB's. pffffffff
Originally Posted by Noz1974
Thanks woodman!!
I bought her with a blown engine originally me and a friend were going to break her to sell the parts and make a bit of cash but when the guy dropped her off I just thought no way!! So I dropped the engine and box and stripped the original engine down. ( it would not turn on the crank , bad sign!!)
The engine had popped a core plug in the cylinder head and water got into the oil system, when I got into the bottom part of the engine i found that a rod had seized on the crank so the crank was toast and the rod plus scoring on a couple of the cylinders etc.
On a good note I actually made £1800 from the good parts , the heads some of the Pistons , one guy even bought a case half off me even though I told him they were a matched pair!!
I then bought a running engine from a local porsche breaker but decided to strip this down and totally go through it with new parts, it's been really enjoyable although a bit tight in my single garage!!!!
With a bit of time and patients I'm sure anyone can do it , you just need to be careful and not rush into anything before doing your research.
Check out 986fix on YouTube , it shows a guy fully rebuilding a boxster s engine, I actually used this to help me when I got stuck , it didn't give all the answers but was a help!!
Old 05-03-2016, 04:30 PM
  #32
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,290 Likes on 902 Posts
Originally Posted by San Rensho
Also look at the Hartech theory. They believe that in the later 996 997 motors thr favtory used a head gasket that would fit either bank (to save money of course) but to do so the gasket had to have all the coolant cut outs the same size. Previous gasket had cut outs that had much bigger openings for 6 and 5 cylinders since they Were the furthest from wster pump and would overheat.
So the new gasket caused 6 to overheat and score.
I do not concur with that theory at all. The change that was made was not significant enough to cause this issue. If anything were to occur from this head gasket change, it would be a cracked cylinder head.
Old 05-03-2016, 05:03 PM
  #33
gnat
gnat's Avatar
Hush you. You can't keep hysteria alive with something as silly as facts!
Old 09-19-2016, 08:36 AM
  #34
AWDGuy
AWDGuy's Avatar
say someone was going to write to Porsche about their 1st Porsche owning experience and their disappointment with the frequency of scored cylinders, where would once send such a letter?
Old 09-19-2016, 08:40 AM
  #35
Flat6 Innovations
Former Vendor
Probably to HQ in Atlanta.
Spending the same time to do something constructive would be the wiser choice, though.
Old 09-19-2016, 09:06 AM
  #36
AWDGuy
AWDGuy's Avatar
such as?
letter was written in 10 minutes. 3 pages documenting my whole 2500km Porsche experience....lol
Old 09-19-2016, 12:52 PM
  #37
gnat
gnat's Avatar
such as?
I think he was referring such productive things as watching paint dry, watching mold grow, holding your breath, counting atoms in your fingernail, ...
Old 09-19-2016, 02:37 PM
  #38
AWDGuy
AWDGuy's Avatar
lol, you never know.
I wrote to canon once for an issue I felt was a quality control thing.
They must of thought the same as they sent the newest camera and a carrying bag as replacement.
All I buy now is Canon products when it comes to my camera needs.
Old 09-19-2016, 02:41 PM
  #39
gnat
gnat's Avatar
True. My dad has a similar story about Bose speakers that were older than I am now that got trashed in their last move. They couldn't/wouldn't fix them and instead gave him couple of sets of their satellite system which actually worked out better for the new house.
I would suggest not expecting a 991 to show up in your driveway though
Old 09-19-2016, 02:43 PM
  #40
AWDGuy
AWDGuy's Avatar
haha, yeah, no worries, I'm not expecting anything.
Old 09-19-2016, 03:29 PM
  #41
Flat6 Innovations
Former Vendor
Arguing with a German about technical things is equal to banging you're head on a Titanium I beam..
Old 09-19-2016, 04:29 PM
  #42
Schnell Gelb
Schnell Gelb's Avatar
"Arguing with a German about technical things is equal to banging you're head on a Titanium I beam..
Jake Raby"
Oh to be a fly on the wall when such conversations occur :-). I hope he doesn't mention Winston Churchill to said I beam!
Old 09-20-2016, 01:12 PM
  #43
AWDGuy
AWDGuy's Avatar
add another:
https://rennlist.com/forums/996-foru...6-ticking.html
Old 12-15-2016, 06:08 PM
  #44
AWDGuy
AWDGuy's Avatar
https://rennlist.com/forums/996-foru...l-startup.html
Old 12-15-2016, 06:09 PM
  #45
AWDGuy
AWDGuy's Avatar
https://rennlist.com/forums/996-foru...cylinders.html
Quick Reply: Scored cylinder failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2)
