Pending Projects
What projects have you planned for your 996? As most of us are pretty meticulous when it comes to maintenance it would be interesting to see what other people have on their list. Here is mine:
Short Term Preventive Maintenance (PM) Plans:
1. Water Pump, LT Thermostat, Coolant Flush, Coolant Line inspection, Serpentine Belt.
2. Bumper removal and radiator clean up.
Long Term PM Plans (or when I'm forced to):
1. AOS
2. Brakes/Rotors
3. Been reading a lot about chain guide issues and I wonder how intrusive of a PM that would be and how much $$$?
4. I believe the suspension is beginning to show it's age.
Upgrades/Mods:
1. Bluetooth ... I hate browsing through radio
2. Fister D or Gundo Hack
3. 997 shifter (maybe)
4. Body color paint of center console and horseshoe
5. Suspension?
That's really it for me. I'm also interested in "must have" suggestions.
2) Time for some new pads, or maybe pads and rotors, depending on what the caliper tells me.
3) Repaint the passenger-side rocker.
I'd like to pull the clear bra off the nose, but I am certain there are a couple of cracks in the paint from collisions with cones/pets/whatever over the years, and the thought of peeling huge sheets of paint off of the bumper is preventing me from tackling this job. It's going to turn into a respray, and I don't want to spend that money right now.
The 996 is in good shape, so most work will be to keep it in good shape. The Corvette, though...
1) Need to repair the center console
2) Need to make a couple of hatch carpet repairs
3) Find (or make) a CF roof panel - the acrylic is going to bust before too much longer, and I don't want to be roofless
4) Swap out the line lock switch for one less noticeable, so it's not OBVIOUS that the car is set up to be a burnout machine
Down the road - have the front bumper repainted and begin a regular oil change regimen with analysis at each change. I am also considering using Reviver to freshen the color of the convertible top.
1. Maybe a bumper respray - everyone tells me it looks fine, though
2. New wheels
1. AOS
2. Brakes/Rotors - last oil change my indy said they were at 70%, so I've got time
3. IMS when the clutch is due (currently also about 70%)
4. Shocks - they just seem a little dodgy to me...
Upgrades/Mods:
1. Maybe new wheels belong here
2. Possibly look at some suspension stuff
1. Car is scheduled to have the windows tinted in a couple of weeks. Doing 40% all around.
2. Getting rid of the awful shift ****. I cannot stand the shape of that thing. I have the OEM plastic retaining piece for the boot on order, as well as an e-bay alcantara boot. Didn't really want to cut up the original, just in case. Still trying to decide on which **** to go with - it's between the Function First, Rennline, or an OEM 997 ****.
Car is a 2004 with 56k and it seems soft and squishy in and out of corners, probably time, thinking OE or Bilsteins, but not a track setup.
However, the fairly delicate nature of the 996's black paint has interfered with my driving event plans, so I've been using my Corvette more for stuff that involves potential cone impacts.
I'm also having a very occasional issue with the ABS/PSM lights coming on. This may be due to my LED tails, but I'm wondering if it's being exacerbated by the UD pulley resulting in the alternator turning slightly more slowly than intended.
I absolutely still recommend the UD pulley as the cheapest way to wring additional performance out of the M96.
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
On deck: Pads/rotors eventually ... still OK but probably will need replacing next year
Suspension ... will need a refresh sooner or later
T96 steering wheel ... just got it a couple days ago and haven't installed it yet
Onboard computer hack ... have 4 stalk switch and wiring harness, was waiting on new steering wheel
Shift cable replacement ... have Numeric cables sitting in a box
RemoteTOP controller ... also sitting in a box, as I just got it recently
Radar detector ... haven't figured out a good way to mount the laser antenna yet
Heated seats ... on the drawing board, probably in conjunction with re-covering the front seats
Already done: Wheels/tires ... replaced the 17" twists/OEM Bridgestones with 18" Sport Designs and Michelin PSS
Kenwood nav head unit
Gentex auto dim mirror with Homelink
LN deep sump kit, stainless baffle, spin-on filter adapter, and magnetic drain plug
New water pump, serpentine belt, and low temp thermostat
Numeric Racing shifter
TWM stainless steel shift ****
Center radiator kit and coolant tank replacement
Zunsport intake grills (more expensive than Home Depot DIY, IMO better looking)
Bi-xenon headlight conversion (currently out of the car as I need to rewire the parking lights)
LED tail lights
Body color bumperettes
LED tail lights
