996 Forum 1999-2005
Loose steering
Old Apr 2, 2015 | 12:54 AM
Soyaudi's Avatar
Soyaudi
2001 C2 When driving on wavy or bumpy roads the car feels like its being pulled side to side and I have to keep the steering wheel straight. I just had the alignment done and it still feels this way. Any suggestions before I go to the shop?
Old Apr 2, 2015 | 10:03 AM
Sonoma707's Avatar
Sonoma707
Do you have stock suspension? Mine acted that way until I installed the RowM030 suspension and the front end vague, floating sensation went away. The Row set up lowers the front end giving the steering a more solid feel.
Old Apr 2, 2015 | 10:24 AM
alpine003's Avatar
alpine003
You'll probably need to replace your tie rods and/or ball joints.
The alignment shop should be able to check this.
Generally on any high mileage or abused cars tie rods, ball joints, control arm bushings wear out.
Old Apr 2, 2015 | 01:11 PM
Soyaudi's Avatar
Soyaudi
Stock suspension with 78k and I was trying to find a way to describe it and floating feel is exactly it.
Old Apr 2, 2015 | 02:33 PM
Ahsai's Avatar
Ahsai
What tire pressure are you running?
Old Apr 2, 2015 | 02:37 PM
alpine003's Avatar
alpine003
Oh that's different than what you initially described it. If it's floating feel and you just got your car aligned, I would have to say upgrading suspension/aero could solve it as it's done for most peeps.
Old Apr 2, 2015 | 02:43 PM
Soyaudi's Avatar
Soyaudi
34psi fronts
40psi rears
Not sure if alignment shop set it like that last week or not.
Old Apr 2, 2015 | 02:44 PM
Spokayman's Avatar
Spokayman
Even though an upgraded suspension is best, the stock suspension shouldn't really feel like it's floating.
Are your struts in good condition?
It is amazing how bad a vehicle will behave when shocks/struts are worn.
Old Apr 2, 2015 | 02:46 PM
Ahsai's Avatar
Ahsai
I'm with Alpine on this one. However, if you just got the car and came out from other front-engined cars, 996 will feel very light in the front and that's normal.
In general, compared to other cars there are tons of feedback in the 996 steering wheel so you can read exactly what your front tires are doing. So maybe that's part of it too.
Old Apr 2, 2015 | 03:08 PM
Soyaudi's Avatar
Soyaudi
This is the only Porsche I have driven so its kanda hard to say how they feel without comparing to a good set up. I put about 2-3k since september.
Old Apr 2, 2015 | 03:11 PM
Soyaudi's Avatar
Soyaudi
I live in North Jersey and work in the city so taking the car on the Harlem River Drive/ FDR is a pain. A 911 has to feel better than this.
Old Apr 2, 2015 | 04:06 PM
alpine003's Avatar
alpine003
Have another member or Porsche specific mechanic drive it.
Old Apr 2, 2015 | 04:09 PM
Soyaudi's Avatar
Soyaudi
Maybe Ill see someone at the Hersey Swap.
Old Apr 2, 2015 | 06:00 PM
5CHN3LL's Avatar
5CHN3LL
What tires? Some tires are true ditchfinders - they'll track you right into the nearest ditch and/or bridge abutment. I found P-Zero Rossos to be exceptionally twitchy.
When you had your suspension done, did they provide the before and after specs? What are they, especially toe and caster?
Old Apr 2, 2015 | 07:20 PM
Soyaudi's Avatar
Soyaudi
18" Pirelli p zero rosso's and the suspension has not been done.
