Wind deflector red tabs
Getting car back to perfect. Still need a wind deflector. On eBay they are about $200 for one with a broken tab $400 for new. I have never seen one in person. They all say that they work fine without the tab. What is the red tab for and can anyone confirm whether it matters?
The red "tabs" act as handles and locks that let you slide the spring loaded locating pins & lock them away from the escutcheons that hold the front of the wind block against/near the seatbacks, while you are mounting the wind block.
As long as the pins are still captured in the wind block and have spring pressure you could use it.
It will be awkward mounting it. You will have to push the pins in with your fingers while you slide the tabs in above the rear seat belts and line up the center support pin.
I see them on Craigslist often; http://losangeles.craigslist.org/lac...850124942.html
I have a wind deflector w/ red tabs in place but small hole in mesh behind passenger seat from hook on back rubbing up against it. Otherwise in very good condition. There is no bag as my Cab has holder in front of spare tire cover. $150. + shipping. If interested pm me.
There is no trick, it just flexes in the middle around the simple hinge. As it happens, my frame broke and I'm trying various kinds of glue to put back together. I may try spraying some WD-40 in the hinge afterwards for easier folding in the future.
It just folds in the middle. I would definitely get one with the Red tabs. Its hard enough as it is to avoid scratching the leather around the mount point. Also, once the windscreen is in, the screen can fold down from vertical to horizontal position - great feature as visibility out the back is impaired with the screen in the vertical position.
The red tabs are easily repairable. There is a factory repair kit. I did this on my wind deflector a few years ago.
I think the part numbers are
996 561 955 00 (left)
996 561 956 00 (right)
