first break down.
12-04-2014 | 03:35 PM
first break down.
Currently waiting for a tow, car puked out a lot of coolant from the rear.
I hope this will be an easy fix.
12-04-2014 | 03:40 PM
Hopefully just a busted coolant hose or bad water pump.
12-04-2014 | 03:41 PM
I dumped about a gallon of coolant from my Boxster (also an M96) between laps at an autocross - the engine was VERY hot, and I was waiting in pregrid for my next turn.
The issue turned out to be a failed coolant tank cap...I hope your diagnosis is equally benign.
12-04-2014 | 03:45 PM
Quote:
Originally Posted by
Ahsai
I suspect a bad water pump, because before I shut her off it made a funky sound.
12-04-2014 | 03:46 PM
5CHN3LL
fingers crossed, thank you. If only the tow truck would be here any faster.
12-04-2014 | 03:54 PM
911661
But think of how cool it will look when it's on the flat bed! Best of luck!
12-04-2014 | 04:05 PM
Possible AOS too. When mine went bad it was a gusher...
12-04-2014 | 04:22 PM
Paul Waterloo
is that a 951? I had one of those and it was on a flat bed as well, it caught fire on me. Boy do I have bad luck with cars at times.
12-04-2014 | 04:23 PM
Gonzo911
hopefully water pump, a cheaper fix than the AOS.
12-04-2014 | 04:40 PM
911661
951 in its natural habitat.
12-04-2014 | 04:46 PM
Paul Waterloo
lol yes, let me tell you scorching flames are a lot scarier than steam.
What sort of "funky sound"? More than likely with a sound it was the water pump blowing a seal. Not a bad fix, probably time anyway. Good luck!
12-04-2014 | 04:54 PM
DBJoe996
my first reaction was to shut it off, then after some thinking it sounded similar to maybe the water pump impellers smacking about?
12-04-2014 | 04:58 PM
911661
Be sure you retrieve all the impeller pieces so they don't block coolant flow!
12-04-2014 | 05:07 PM
If its really the WP impeller explosion, someone better explain this or he's going to experience the dreaded CEF of MOF #???
