996 Forum 1999-2005
first break down.
Old Dec 4, 2014 | 06:04 PM
  #31
alpine003's Avatar
alpine003
911661 or any of the newer guys, if you wanna know KK in a nutshell, look here at one of his more famous threads...
Paul, I think you may have covered more miles in you picking up your car than what KK has done with his entire length of ownership.
https://rennlist.com/forums/996-foru...road-trip.html
Old Dec 4, 2014 | 06:10 PM
  #32
DTMiller's Avatar
DTMiller
Does the vertical travel of the engine as it is dropped and reinstalled count as mileage?
Old Dec 4, 2014 | 06:13 PM
  #33
911661's Avatar
911661
haha gotcha thanks for looking out
Old Dec 4, 2014 | 06:19 PM
  #34
Gonzo911's Avatar
Gonzo911
Rat Balls
You know you are Krazy when the Moderator of the 996 board offers you this advice:
Post #7: Just sell your car. A car that causes you this much stress is not worth owning. Marc Gelefsky/Super Moderator
Old Dec 4, 2014 | 07:18 PM
  #35
Sneaky Pete's Avatar
Sneaky Pete
Man I needed to see that old thread. Just made a ho hum day into a winner.
Old Dec 4, 2014 | 07:26 PM
  #36
Byprodriver's Avatar
Byprodriver
Originally Posted by 911661
I just did some reading. From my understanding if the water pump impellers were to break they would be logged into the coolant passages and cause hot spots which in return cracks the head or makes your head gasket fail? If that's the case to remove the plastic impellers does the engine need to be taken apart?
Hopefully all pieces will be accounted for during the through flushing of old coolant in preparation for new Porsche coolant. If they are lodged in the heads, it's more difficult to retrive. The 99-01 models crack heads easily.
Old Dec 4, 2014 | 07:36 PM
  #37
Macster's Avatar
Macster
If (big if) the impeller did come apart and there's nothing but speculation on this, but if the thing did come apart rigging up some pump that pumps water backwards through the engine (and if necessary the radiators through not at the same time as the engine) would flush the pieces out.
Old Dec 4, 2014 | 08:09 PM
  #38
911661's Avatar
911661
hopefully nothing is lodged anywhere, I do hope tomorrow morning when I take the car in to the mechanic nothing is majorly wrong. Fingers crossed
Old Dec 4, 2014 | 08:10 PM
  #39
911661's Avatar
911661
if the case, hopefully my mechanic has something of that sort to suction out the pieces
Old Dec 5, 2014 | 05:17 PM
  #40
cobra935o's Avatar
cobra935o
I just had the water pump go on my car a few months ago. When I pulled the pump, the impeller was in pieces, and they were all laying right there in the cavity where the pump is installed, once I pulled the pump, and the thermostat, I had all the pieces. I was able to fit all the pieces back together on the bad pump to even ensure that I had all the pieces. I am no expert, but feeling around in there, unless the impeller had completely smashed up in to really tiny pieces there is really no where for them to go, as the passages arent that big. I posted pictures of mine on the 40th AE thread.
Old Dec 5, 2014 | 07:18 PM
  #41
911661's Avatar
911661
that is actually very reassuring news! I think all will be well on my car
