996 Forum 1999-2005
Cab Questiion
Old Sep 29, 2014 | 07:05 PM
Idocdes's Avatar
Idocdes
Question Cab Questiion
My 2002 911C4 convertible top will not raise to recover the car? When depressing the button to raise the top the indicator light in the car flashes but nothing happens. Any insight into a fix is greatly appreciated.
Old Sep 29, 2014 | 07:47 PM
Gonzo911's Avatar
Gonzo911
Rat Balls
Could be a number of things. Are you hearing anything from the cab motor? If not, then it could be your eBrake sensor. The eBrake is engaged, but your car thinks its not. Happened to me...
Old Sep 29, 2014 | 07:59 PM
Colorado Bob's Avatar
Colorado Bob
Put your key in the drivers side door lock and turn it to the right (or left I can't remember) and hold it there and it should raise the top and windows. If your top operates then your ebrake switch is probably bad. Also check to see if both deck lids are closed. My rear deck was not latched and the top would not come up.
Old Sep 29, 2014 | 08:46 PM
Idocdes's Avatar
Idocdes
Colorado Bob...That did! Top back up, will bring in for replacement ebrake sensor.
Old Sep 30, 2014 | 09:39 AM
rwiii's Avatar
rwiii
Glad that worked and for anyone else make sure the trunk is completely closed. That will also prevent it from engaging.
Old Oct 1, 2014 | 12:01 AM
fpb111's Avatar
fpb111
2002 can raise the top at speeds up to 30mph.
Old Oct 1, 2014 | 01:20 AM
smorris's Avatar
smorris
nope... not without adding an aftermarket work around.. or clicking the e-brake up just enough to engage the switch while driving slowly!
Old Oct 2, 2014 | 08:34 AM
frisbee91's Avatar
frisbee91
I snipped the "pink wire" speed sensor to the cab top module. Now, I can click the e-brake up one click, and raise or lower the top while moving. I only use it in parking lots or driveways, while moving under 20 mph.
Here's the DIY
http://www.renntech.org/forums/topic...-while-moving/
