996 Forum 1999-2005
IMS Retrofit Pro vs. Classic
Old 08-19-2014, 05:15 PM
Copilot
Copilot's Avatar
From everything I've seen, the Faultless tool sells for around $700 so if you're supplying yourself... No reason NOT to do the solution, in my opinion. A few hundred bucks more and you're at least in the same place for parts cost.
Old 08-19-2014, 05:25 PM
Rubik
Rubik's Avatar
I just upgraded mine and I went with Classic; tested and tried. The dual looks better and theoretically should be more bullet proof, but it's new. Perhaps the next time I upgrade (if I still have my 996), I'll go with dual.
Old 08-19-2014, 06:51 PM
tdrimer
tdrimer's Avatar
My shop had the tool. They have done a few...
Old 08-19-2014, 09:20 PM
alpine003
alpine003's Avatar
I find it ironic that the "faultless" tool can offer basically an idiot proof install, however it may not really guarantee anything if there is no pre qualification phase done on the engine.
The IXX retrofit regardless of which version gives a false sense to the owner if there is still debris in the motor from a lack of prequalification phase.
Obviously having that decal(unless China starts making and selling reps) should make one worry less, if you are naturally a worry wart.
Old 08-20-2014, 12:19 AM
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,290 Likes on 902 Posts
The Faultless Tool only facilitates bearing extraction and insertion. These are the simplest, most straight forward pieces of the IMS Retrofit procedure and the hardest to screw up with the tool.
What matters above all else is the pre- qualification procedure and time being spent to ensure that the engine does not have some hidden, in progress failure. The issue is IF a shop finds an issue will their employee who is doing the work have the integrity to stop and bring the condition to someone's attention? Its not his shop or his engine, but it is his commission if the job gets canceled due to some issue that makes it no longer be a viable IMSR candidate. IMS Solution Certified Installers will lose their certification if they do not follow the code of conduct that is agreed to up front, which is very clear.
Just last week we completed another M96/ M97 hands on school here and that class netted us 4 more potential Certified Installers for the IMS Solution as they were invited to begin the evaluation processes. Two of these were Canadian, the other two were from the US.
The practice of bearing extraction and insertion is so simple that a 12 year old could do it, its the rest of the process that requires sense and situational awareness.
Old 08-20-2014, 12:38 AM
alpine003
alpine003's Avatar
So at least 75% of these people that have had the IXX procedure done elsewhere most likely without proper pre-qualification are getting false sense of security and should have them redone or stay awake at night worrying if they have debris or impending damage. Yes I'm playing the new KK role. Lol
Old 08-20-2014, 02:00 AM
Flat6 Innovations
Former Vendor
Pre- qualifications are nothing new. In fact from the very first day that I developed the IMSR procedure the precursor to it was a clearly defined pre- evaluation.
In the beginning, 6-7 years ago we never had issues with people following directives to the T, because the procedure was new and considered "black art", because Porsche said the IMSB couldn't even be removed. Shops and techs were afraid of the job and because of that they did not take risks, nor did they deviate from the procedure at all.
Fast forward to late last year when the class action was hot news and IMSB sales increased by a few hundred percent in a couple of months, because the issue was finally "real" to all the naysayers. This created a huge shockwave of issues because shops were fighting 9and still are) to get all the IMS work they could and take it from the other guy. With this came more experience with the jobs and with that came a sense of over achievement by techs. This is the root of the issue because they started to cut corners and that allowed the work to be done faster, and therefore they could do it cheaper than the competing shop across town. What made it worse is owners price shopping shops rather than understanding that quality work trumps cheap work when concerning Porsche engines.
Today we receive 2-3 complaints per week from people stating that Midas mufflers did their IMSR, or even a big rig shop, or like today, a unit was installed at a Pep Boys by a guy that changes tires all day. These people are competing with Porsche shops and making the shops that used to be good lower their standards just to get the work. Don't think that just because your shop has 30-40 years of experience that they are good, because those shops are constantly having the issues too, and often they are the leaders of the problem because they are busy and rush through things.
Things like dumping used oil with 5-8K on it back into the engine with a fresh IMSR fitted, rushing the job by not pulling the sump or even removing the oil filter and etc are creating issues. One shop had a tech whop was installing the IMSB using an impact wrench to save time!
All we can do is alert the owners of these things so they can ensure that they are not falling prey to someone who treats the IMSR like a brake job and just goes through the motions playing the part, only to botch the install and compromise our product.
LN has employed a code of conduct for all Preferred Installers to try and reduce these issues by giving the shops something to lose if they do not do whats best for the customer and the technology. I oversee the IMS Solution Certified Installers personally and constantly challenge each of them to do the right thing, even when no one is looking. I've been known to pull a Certification with one bad judgement call being made by a Certified Installer. They are all given a single chance, they hold our entire reputation in their hands.
I take this stuff seriously, because I did it first, and we created it… The pride means more than the profit.
Old 08-20-2014, 08:49 AM
PORCAR
PORCAR's Avatar
The bottom line here is folks need to research the installer before moving forward. While I respect Flat's dedication, I also feel there is a bit of self motivation involved. Solution installers are few and far between. Most people don't have the time or money to flatbed their car to one of these locations. I for example, went with a shop that is used by rich lawyers. Why? You can guess why.
Old 08-20-2014, 09:27 AM
Flat6 Innovations
Former Vendor
Yes, and quiz them on what their procedure consists of. There are many ways to carry out the IMSR.
If it was all about self motivation, and if we wanted all the work we never would have allowed the IMS Solution to be distributed. In that case we would have simply retained the technology and not allowed it to be installed outside our facility. We took the time to deal with the Patent process primarily for this reason.
If a shop doesn't carry out a proper install WE have to deal with it, and it gets really old, really fast. Trust that this is the only "self motivation" that I have with these posts.
Yes, and we have no intention to put one on every corner. Doing that would defeat the purpose of the program and we'd still have issues to deal with, that we don't have today. IMS Solution Certified Installers begin their quest by simply attending my WTI class and then taking the initiative to attend the "102" version of that class here at my facility, which is hands on. If someone impresses me in the way they hold a wrench, the questions they ask and if I feel good about them, we'll extend an invitation to the program to them at the end of the class.
Shipping is easy, in fact its the simplest part of the process here and I have one employee who only handles brokering of cars and shipping.
I just finished one of my hands on classes last week. In that class we had 20 attendees and invited 4 more potential Certified Installers to the program (2 USA and 2 Canada). Now the evaluations of these shops begin, and that includes an onsite visit as we evaluate their performances while carrying out an IMSR procedure. They then have a written test that is very difficult to pass.
Ultimately one installer per state is all we are shooting for, but what matters most is sniffing out the best shop in that state to Certify and ensuring that they stay that way. We can't do it all, and if we did, it wouldn't be special enough to motivate me.
Choose the guy with the most beat up hands.... That tells you that he does less with a computer and more with wrenches and is more of a mechanic than a technician. That matters most.
Old 08-20-2014, 01:07 PM
alpine003
alpine003's Avatar
Is this infomercial still running?
Old 09-19-2014, 08:29 PM
nickdee62
nickdee62's Avatar
I have the single row pro retrofit, the "faultless" tool and the classic tool kit. I will be doing mine this weekend. That tiny retainer clip scares me! I will be back with a full report next week!
M96 in a 2002 Carrera
Old 09-19-2014, 11:05 PM
Flat6 Innovations
Former Vendor
The "tiny retainer" is the same wire lock size and positioning as a factory Porsche dual row IMSB. These are the units that will break most pullers when extracting, if you try to remove the Single Row Pro after its in place you'll see that the wire lock does an amazing job at retaining the bearing. The wire lock has to break or shear during extraction to allow the bearing to be extracted.
The "anodized black part" that you referenced in your message is used only to install the IMS Solution bushing, they are not used with the Single Row pro. Remember, the Faultless Tool extracts and installs all the different IMSBs as a universal tool.
Please read the instructions thoroughly.
Old 09-21-2014, 11:16 PM
Copilot
Copilot's Avatar
How did it go? I'm curious as I haven't seen any DIY Faultless tool use/Single Row Pro use yet.
Old 10-02-2014, 10:13 AM
nickdee62
nickdee62's Avatar
Jake probably doesn't want this known but he is a great guy! I actually got a call from him personally when I asked for some tech support!
After Jake's few tips, I had a "faultless" installation. The key is to make sure you have perfect alignment of the tool and the bore, push the bearing and clip into the tool about 3/16 so that the clip is past the taper before you start and use lots of light lube.
That dual row bearing and the related hardware L&N supplies makes the stock stuff look really insufficient. The wire clip retains the bearing extremely well, too.
I'm very happy to have made the investment I enjoy working on my own cars and have been wrenching on them for over 40 years. Even though the IMSB kit and tools are not recommended as DIY, if you have the experience and resources this is a straightforward procedure.
I will be posting my experience with some pics as soon as I get some time.
Last edited by nickdee62; 10-02-2014 at 10:20 AM. Reason: added "before you start"
Old 10-02-2014, 02:16 PM
KrazyK
KrazyK's Avatar
He is a great guy.
To simplify the engine qualification process for DIY'ers here's what I did before my install and I'm certainly no pro.
1. verify engine overall health/performance. Oil analysis is a good idea but not mandatory.
2. verify no debris in filter or drained oil.
3. verify no debris in pan.
4. verify no debris / problems during disassembly / extraction / install.
If you just do the simple above steps, your engine has been qualified the simple DIY way.
Quick Reply: IMS Retrofit Pro vs. Classic
