996 Forum 1999-2005
Leaking IMS seal?
Old Jun 20, 2014 | 07:15 PM
grain's Avatar
grain
Default Leaking IMS seal?
I had a leak, so I dropped the trans and seems that it's the IMS seal. I called the dealership that serviced the car before I bought it and they said they replaced clutch, ims and rms at 64k miles. Car is at 72k now.
What are the chances that they replaced the ims with a LN retro fit?
Also curious if the pp or flywheel look ok. Clutch is 8.44mm thick.
Hoping that I can just replace the ims seal.
File Type: jpg
File Type: jpg
File Type: jpg
Old Jun 20, 2014 | 07:27 PM
KrazyK's Avatar
KrazyK
I think I would ask for the proof of what they replaced. Looks like they f##$% up. You got it this far. Keep going, the rest is easy.
Old Jun 20, 2014 | 07:39 PM
alpine003's Avatar
alpine003
Most likely the dealer only replaced the IMS flange seal which is standard protocol for a dealer.
Old Jun 20, 2014 | 07:52 PM
grain's Avatar
grain
After reading more, it seems that oil leaking from this is bad because that means the seals on the bearing itself is gone allowing oil to pass through? Unless i'm over thinking it. I'd like that have a reason not to use the 1000 dollar parts i've already ordered.
Old Jun 20, 2014 | 11:08 PM
Flat6 Innovations's Avatar
Flat6 Innovations
Former Vendor
That engine has already been retrofitted. Thats an LN IMSB flange. I can spot one from 20 yards away.
Looks like its leaking at the nut, my guess is they botched the install by compromising the O ring in the IMS flange ID when installing it.
Old Jun 20, 2014 | 11:25 PM
grain's Avatar
grain
So what should I do? Install the new oring from my LN kit?
Old Jun 21, 2014 | 12:14 AM
Flat6 Innovations
Former Vendor
Pull the flange off and find the leak.. You must follow the same procedure as an IMS Retrofit to do this, else the timing will be compromised.
Old Jun 21, 2014 | 12:24 PM
grain's Avatar
grain
Is this the LN bearing? Just making sure, since the LN bearing I bought looks a little different that this one.
Seems there wasn't an o ring installed.
File Type: jpg
Old Jun 21, 2014 | 04:09 PM
Flat6 Innovations
Former Vendor
Since day #1 (meaning the very first IMSB ever installed, done at my shop) all LN IMS bearings have used an O ring to seal the ID of the flange to the center stud.
If its not there, you will have a leak.
