Why is it necessary to change oil after one year regardless of low mileage?
I really don't know as my motor blew with 2k miles on it. I suspect the previous owner over revved it and/or didn't break it in correctly. I wasn't happy to say the least. Got a used motor replacement but still hung onto my original motor. Love the midrange v twin torque. Great for wheelies. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Oh yeah, oil, what Jake says....
2002 Turbo - Basalt Black Metallic / 2003 Carrera 4S - Speed Yellow / 1955 356 Continental 1500 - Rust Red
Received 1,179 Likes
The AOS bleeds crankcase pressure back to the intake manifolds. Now back to the OP's original question - why do I have to change the oil? For that matter, why change the oil filter, air filter, tires, brake pads, brake fluid, pollen filter, or add air to the tires??.... It's a Porsche and that stuff will last forever. It's your car and you can do whatever you want. I keep mine exactly the way it left the factory and never change anything. Those car engineers/manufacturers have no idea what they are doing, and c'mon, they are really just creating circumstances where you have to go back to the dealer for service so you'll lust after all the new models and end up buying one. The heck with that...rebel and don't fall it! Make a new revolution and never, ever follow anyone's advice, especially a bunch of Porsche engineers, or Jake even.
The AOS bleeds crankcase pressure back to the intake manifolds. Now back to the OP's original question - why do I have to change the oil? For that matter, why change the oil filter, air filter, tires, brake pads, brake fluid, pollen filter, or add air to the tires??.... It's a Porsche and that stuff will last forever. It's your car and you can do whatever you want. I keep mine exactly the way it left the factory and never change anything. Those car engineers/manufacturers have no idea what they are doing, and c'mon, they are really just creating circumstances where you have to go back to the dealer for service so you'll lust after all the new models and end up buying one. The heck with that...rebel and don't fall it! Make a new revolution and never, ever follow anyone's advice, especially a bunch of Porsche engineers, or Jake even. ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
If you want to know the truth, just analyze your oil over time based on your current driving habits etc, and you should be able to tell when you need to change the oil..... or just follow the recommended procedure and feel confident that you are covered.
BTW - Porsche engineers recommend changing oil every 15k miles, so lets not just assume that this is "what's best for the car" The recommendation was probably based on a replacement timeframe of 7 years or so, and not meant for 15 year old cars.
Former Vendor
Trust that the health of the engine isn't the only consideration in these service intervals. When buyers look at the cost of ownership they don't want to see that 3-4 services are required per year at 3-400 bucks a pop. Even though this is really the case, they still don't want to see it. The same for leasing companies, I am blown away at how many broken cars that we buy that were originally owned by a leasing company. The leasing companies won't fill their fleets with cars that require a ton of service as they are responsible for it.Its no coincidence that the cars that seem to break so often were originally a leased vehicle, because they only got the service that the factory called for, nothing more.
And, I don't care if the oil will last a year, when I change my oil I want to purge impurities from the oil sump that are there from the combustion processes. Whether the oil is good or not, it is laced with impurities. These engines are even worse as they are notorious for fuel intrusion that stems from a lack of ring seal and over enriched starts cycles that are meant to light off catalytic converters faster.
Its the things that you don't know that always worry me.. Thats why I work to learn as much as I can, never stopping and never giving up.
