996 Forum 1999-2005
Gundo hack/Fister D
Old Mar 10, 2014 | 05:28 PM
Sarki's Avatar
Sarki
Anybody in the northeast, specifically metro NY area have the Fister D mod done at a local shop?
I'm with Mark in the fact that I'd rather get it done locally and not deal with the cost, hassle & down time involved in shipping mine out to the west coast.
Any recommendations are appreciated.
Old Mar 10, 2014 | 06:10 PM
dmw996's Avatar
dmw996
Do it. I just had the "Fister D" done this past January. I think it is the best mod for the $.
Old Mar 10, 2014 | 09:14 PM
996_North's Avatar
996_North
Originally Posted by Revn29k00
Has anyone here done both mods here? Can it be done and is there any improvement to sound?
Mine is a 3.4 and i did the Gundo and i may go back and do the Fister at some point, as i think i need more.
HYPER911 is on the forum and he had both done if I recall.
Old Mar 10, 2014 | 09:21 PM
bornrich's Avatar
bornrich
As far as I know the Fister mod and the gundo hack are the same modification. The only difference is Fister is a company that you can send your cans to for the mod and the gundo hack are directions for a local muffler shop to do the work.
Old Mar 10, 2014 | 09:25 PM
996_North's Avatar
996_North
they are different, check the photos in the second post to this thread.
Old Mar 11, 2014 | 03:17 PM
fpb111's Avatar
fpb111
The original Fister and Gundo were the same, and they are the same as PSE without the PSE shutoff solenoid. That hack was quieter on 3.4 mufflers.
Fister started the short pipe in the second pic because customers wanted a bigger difference from stock. The short pipe hack is louder.
Old Mar 11, 2014 | 03:24 PM
fpb111's Avatar
fpb111
Originally Posted by Seeeu911
So...I wonder what a FISTofGUNDO combined mod would sound like ? You know do them both together on the same muffler.
Here is the pic. Now to find the sound clip.
File Type: png
Old Mar 11, 2014 | 07:15 PM
Mark Wagner's Avatar
Mark Wagner
So does anyone know somebody that can do a quality job in the Long Island area if i bring them the mufflers?
Old Mar 11, 2014 | 11:42 PM
gota911's Avatar
gota911
Newbies Hospitality Director
Originally Posted by Mark Wagner
So thinking of going Fister D mod (bypass pipe between inlet and outlet). Looks like a tight fit using a straight pipe due to what appears to be a bolt on the muffler in that first photo. I notice the actual Fister photo shows the bypass pipe with a bend in it but no bolt on the can.
Not ever having the mufflers off the car not sure what to expect. I am most likely going to try to have it done locally to save on time and shipping charges. Can anyone here address my concerns with the use of a straight pipe and tell me what diameter tube to use between both.
Mark,
I spend most of my time on the 997 Forum now, but I am glad I stopped by the 996 Forum tonight because I can help you out.
The "bolt" you referencingiing is actually the clamp that connects the pipe which has the exhatips onpson oppositeosit end to the muffler.
See my post from January 2008 (damn, it's been that long?) for a PET diagram of the 996 exhaust system and instructions how to remove them and a couple of pics which show the "clamp."
996 Exhaust
Hope this helps. PM me if you have any additional questions.
Old Mar 12, 2014 | 12:47 AM
rattlsnak's Avatar
rattlsnak
I did mine with a straight pipe. I used a 1 5/8 pipe. I wanted to use a 1 3/4, but it was too thick. I actually cut the factory pipe off as well and then welded them all in together. Love the sound..
File Type: jpg
Old Mar 12, 2014 | 10:21 AM
Seeeu911's Avatar
Seeeu911
Beautiful job.
Old Mar 12, 2014 | 03:13 PM
C four S's Avatar
C four S
Thanks.... I needed that picture of the other side....
Old Mar 12, 2014 | 04:39 PM
pesuazo's Avatar
pesuazo
Here you go.....
60.00 at the local muffler shop.....
File Type: jpg
Old Mar 13, 2014 | 02:24 PM
C four S's Avatar
C four S
what size tube did you use ? Thanks
Old Oct 8, 2014 | 11:06 AM
911searcher's Avatar
911searcher
Does the Gundo hack make it louder too ?
Porsche 997 Gundo hack 2 Exhaust bypass
I have the Porsche Sport Exhaust (PSE) and I like the sound of that.
Which is a better sound PSE or Gundo ?
Which is louder ?
Can you do a Gundo hack on a car with PSE already ?
Here is a before and after PSE install
