Gundo hack/Fister D
Can anyone provide photos showing left and right modifications. Considering doing this and want to be able to drop mufflers off at a local shop with photos to duplicate the modification.
Thanks, what is the sound difference between both? Hard to tell listening to many of the youtube videos. The first pic, you basically just cut a hole in the can? There is nothing behind that area (hollow space).
The top picture is the way the factory does it except they have a solenoid valve in line so you can turn it on or off but many people complain it is isnt loud enough. The bottom way seems to be the much preferred of doing it. I did it to mine and i love it. It is just about perfect.
So thinking of going Fister D mod (bypass pipe between inlet and outlet). Looks like a tight fit using a straight pipe due to what appears to be a bolt on the muffler in that first photo. I notice the actual Fister photo shows the bypass pipe with a bend in it but no bolt on the can.
Not ever having the mufflers off the car not sure what to expect. I am most likely going to try to have it done locally to save on time and shipping charges. Can anyone here address my concerns with the use of a straight pipe and tell me what diameter tube to use between both.
Mufflers serve no other purpose (to my knowledge) than to turn down the sound of an engine.... Thus there should be no effect on emissions other than noise emissions.
http://auto.howstuffworks.com/muffler.htm
